Fosera Scandle 200 Solar Panel Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
89
All Time:
1,197
Comments: 3
3 guide comments.
Go to guide comments
Completed: 0
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Due to excessive use or damage, the efficiency of the solar panel will slowly decrease over time. Once that time has come, this guide will aid you on replacing a damaged or inefficient solar panel using the existing power cord.
Tools
    1. Fosera Scandle 200 Solar Panel Replacement, Solar Panel: step 1, image 1 of 1
      • Open the case by pulling the back tab toward you in a downward motion.
      Ask FixBot
    2. Fosera Scandle 200 Solar Panel Replacement: step 2, image 1 of 1
      • Unscrew the two Phillips #2 5mm screws that hold the power cord in place.
      Ask FixBot
    3. Fosera Scandle 200 Solar Panel Replacement: step 3, image 1 of 1
      • Use the flat-end of the spudger to pry off the clamp which holds the cord down.
      Ask FixBot
    4. Fosera Scandle 200 Solar Panel Replacement: step 4, image 1 of 1
      • Use the soldering iron to melt down the solder on each terminal by holding the tip of the iron against the solder until it becomes liquefied.
      Ask FixBot
    5. Fosera Scandle 200 Solar Panel Replacement: step 5, image 1 of 1
      • Gently pull the leads free from the terminals. If they do not easily separate from the terminals, repeat Step 4.
      • Now any solar panel of appropriate Voltage rating can be used to charge the device by soldering the wire leads to the new panel. Try to find a panel with similar specifications to avoid overloading the battery.
      Ask FixBot
Vincent C
134 Reputation
1 Guide authored
USF Tampa, Team 12-5, Blackwell Fall 2014 Member of USF Tampa, Team 12-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G5
4 Members
72 Guides authored
3 Guide Comments
In order to use solar energy efficiently, we need to learn how to store solar energy. Unfortunately, we can only store a small fraction of the sun's energy.
niks adonis - Reply Share
More information here.
Go to the link.
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 89
All Time: 1,197
