Fosera Scandle 200 Battery Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
27
Past 30 Days:
88
All Time:
1,403
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 7 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
After too many charging cycles, the battery's capacity will be decreased. This is true for any Lithium-ion battery. Luckily the replacement of the battery in this device is very simple.
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
    1. Fosera Scandle 200 Battery Replacement, Motherboard Removal: step 1, image 1 of 1
      • To open up the casing, you will need to unscrew the four Phillips #0 15mm screws which are accessible from the back.
      Ask FixBot
    2. Fosera Scandle 200 Battery Replacement: step 2, image 1 of 1
      • Gently separate the two halves of the casing.
      Ask FixBot
    3. Fosera Scandle 200 Battery Replacement: step 3, image 1 of 1
      • Disconnect the battery from the motherboard by lifting up on the white plastic tab on the top of the connection.
      • Gently pull the cord out by the white plastic adapter. Do not pull from the red and black cord.
      Ask FixBot
    4. Fosera Scandle 200 Battery Replacement: step 4, image 1 of 1
      • Unscrew the Phillips four #0 15mm screws to free the motherboard from the casing.
      Ask FixBot
    5. Fosera Scandle 200 Battery Replacement: step 5, image 1 of 1
      • Slowly pull the motherboard out of the casing. Make sure the loose battery wire doesn't get snagged.
      Ask FixBot
    1. Fosera Scandle 200 Battery Replacement, Battery: step 6, image 1 of 1
      • Remove the four #0 15mm screws to release the battery housing from the case.
      Ask FixBot
    2. Fosera Scandle 200 Battery Replacement: step 7, image 1 of 1
      • Take the battery housing and battery out of the casing.
      Ask FixBot
Vladislav Ignatov
597 Reputation
3 Guides authored
USF Tampa, Team 12-5, Blackwell Fall 2014 Member of USF Tampa, Team 12-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G5
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 27
Past 30 Days: 88
All Time: 1,403
