Forerunner 620 Battery and/or Screen Replacement
    1. Forerunner 620 Battery and/or Screen Replacement, Remove LCD: step 1, image 1 of 2 Forerunner 620 Battery and/or Screen Replacement, Remove LCD: step 1, image 2 of 2
      • Carefully remove the display of the watch by thoroughly heating the display and gently prying with the help of a suction cup.
      Ask FixBot
    2. Forerunner 620 Battery and/or Screen Replacement, Remove the main board: step 2, image 1 of 1
      • Remove the screws which secure the main board in place.
      Ask FixBot
    3. Forerunner 620 Battery and/or Screen Replacement, Replace battery: step 3, image 1 of 3 Forerunner 620 Battery and/or Screen Replacement, Replace battery: step 3, image 2 of 3 Forerunner 620 Battery and/or Screen Replacement, Replace battery: step 3, image 3 of 3
      • If the connector for the battery breaks, you can solder the connections directly to the motherboard.
      • If the connector is still intact, you can simply clip the new one into place.
      Ask FixBot
    4. Forerunner 620 Battery and/or Screen Replacement, Replace the LCD: step 4, image 1 of 1
      • If the LCD is broken, you can replace it by removing the two flat cables which connect it to the main board.
      • The touch screen cable has a lock with a small white lever which should be lifted gently to remove the cable.
      Ask FixBot
    5. Forerunner 620 Battery and/or Screen Replacement, Glue and put it back: step 5, image 1 of 3 Forerunner 620 Battery and/or Screen Replacement, Glue and put it back: step 5, image 2 of 3 Forerunner 620 Battery and/or Screen Replacement, Glue and put it back: step 5, image 3 of 3
      • You can now glue the display back in place using B-7000 adhesive.
      Ask FixBot
phico
295 Reputation
2 Guides authored
10 Guide Comments
Where did you find the replacement battery?
Clarence Chung - Reply Share
I bought this model on Amazon : "
CELLONIC® Smartwatch Replacement Battery PD3032, 361-00047-0 Compatible with Garmin Approach S1, Forerunner 110, Forerunner 210, Forerunner 610, Forerunner S1 Replacement Battery 200 mAh Battery Fitness Tracker
Philippe Collignon - Reply Share
Do you have the dimensions of the original battery?
Is B7000 adhesive necessary?... or will E6000 also work the same?
Thanks in advance.
jjc - Reply Share
Changed the battery, all good, except that the touch screen is no longer responding to my touch. :<
Past 24 Hours: 0
Past 7 Days: 17
Past 30 Days: 65
All Time: 4,236
