Ford Crown Victoria Hood Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
70
All Time:
299
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 35 minutes
Difficulty: Easy
Community-Contributed Guide
    1. Ford Crown Victoria Hood Replacement, Pop the hood: step 1, image 1 of 1
      • Pop the hood up by pulling the latch located down and left of the steering wheel.
      Ask FixBot
    2. Ford Crown Victoria Hood Replacement, Push the Hood up: step 2, image 1 of 1
      • Reach into the gap between the hood and the header panel to unlatch the hood.
      • Latch circled in red
      • Push the hood up
      Ask FixBot
      • Place a peice of cardboard between the windshield and the hood as too not scratch the windshield
      Ask FixBot
    3. Ford Crown Victoria Hood Replacement, Removal: step 4, image 1 of 2 Ford Crown Victoria Hood Replacement, Removal: step 4, image 2 of 2
      • Use a 10mm socket to undo the 4 bolts. 2 on either side.
      • Have something or someone prop up the hood as you remove the bolts.
      Ask FixBot
    4. Ford Crown Victoria Hood Replacement: step 5, image 1 of 1
      • The hood should be off. Just lift it up and away from the car. Preferably with 2 people
      • Ignore my missing bumper lol
      Ask FixBot
To put the hood back on will not be as easy as taking it off. Gets the bolts hand tight and shimmy the hood around to get proper alignment. Test by trying to shut the hood. Repeat this process until it is aligned. Then tighten down bolts going Top Left, Top Right, Bottom Left, Bottom right. This is to make sure that It shifts less when you tighten the bolts.
Corbanizer
2,532 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 70
All Time: 299
