FoodSaver V4980 Bag Cutter Replacement
    1. FoodSaver V4980 Bag Cutter Replacement, Bag Cutter: step 1, image 1 of 1
      • The bag cutter is a small plastic rolling apparatus in the bag cutter arm.
      • Lift up the top cover to get to the bag cutter arm.
      Ask FixBot
    2. FoodSaver V4980 Bag Cutter Replacement: step 2, image 1 of 2 FoodSaver V4980 Bag Cutter Replacement: step 2, image 2 of 2
      • Pull the sides of the cutter arm apart, and pull on the bag cutter to remove it from the arm.
      Ask FixBot
Mackenzie Grossgold
952 Reputation
6 Guides authored
Cal Poly, Team 34-17, Maness Spring 2016 Member of Cal Poly, Team 34-17, Maness Spring 2016
CPSU-MANESS-S16S34G17
4 Members
72 Guides authored
6 Guide Comments
how do i get a new one
Darlene Paulson - Reply Share
All Out Of Stock everywhere 😕
K E - Reply Share
@oaxxeemidiovbtv my problem also! If you take the little plastic cutter cartridge out, (the one out of stock everywhere) you should be able to carefully open it to replace the blades with new sharp ones. Buy a 9mm knife with the snap off blades…the segments fit perfectly on my FM3920.
Kevin Post - Reply Share
my bag cutter dont cut how do i get a new one & how much
my MACHINE IS BRAND NE, FIRST USE AND IT WILL NOT CUT
James Budelman - Reply Share
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 55
All Time: 4,585
