Foldable Grocery Cart Wheels Replacement
Views: 17K
View statistics:
Past 24 Hours:
18
Past 7 Days:
116
Past 30 Days:
485
All Time:
17,480
Comments: 13
10 comments on steps, 3 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Introduction
Go to step 1 ↓
If you have a foldable grocery cart or shopping trolly, that has its front wheels all worn out, then this guide will assist you in replacing the tattered wheels with new ones so you don’t have to worry about buying another cart. Damaged wheels of your grocery cart can cause your cart to not steer properly or even worse, collapse on the spot. It is important to replace them to avoid such situations and unnecessary expenses.
For the replacement, you can get an extra pair of wheels by buying new ones or use wheels that are in good condition from another cart that is not being used anymore. Just make sure that the wheels are of similar size to the old ones and that the hole is big enough to slide through the axle of the cart you’re currently using (some wheel sizes and center hole sizes may vary, so get a pair of wheels that are compatible with your grocery cart). Before starting, make sure your work area is open and free of any obstacles.
    1. Foldable Grocery Cart Wheels Replacement, Wheels: step 1, image 1 of 3 Foldable Grocery Cart Wheels Replacement, Wheels: step 1, image 2 of 3 Foldable Grocery Cart Wheels Replacement, Wheels: step 1, image 3 of 3
      • Using a large needle nose plier, take out the stoppers from each side of the axle.
      Ask FixBot
    2. Foldable Grocery Cart Wheels Replacement: step 2, image 1 of 2 Foldable Grocery Cart Wheels Replacement: step 2, image 2 of 2
      • Use the large needle nose pliers to pull out the locking pins from the holes in the axel to detach the axel from the cart's legs.
      • Repeat for both sides.
      Ask FixBot
    3. Foldable Grocery Cart Wheels Replacement: step 3, image 1 of 3 Foldable Grocery Cart Wheels Replacement: step 3, image 2 of 3 Foldable Grocery Cart Wheels Replacement: step 3, image 3 of 3
      • Carefully pull out the axle to detach it from the cart’s legs.
      • The washers and springs may fall out.
      Ask FixBot
    4. Foldable Grocery Cart Wheels Replacement: step 4, image 1 of 3 Foldable Grocery Cart Wheels Replacement: step 4, image 2 of 3 Foldable Grocery Cart Wheels Replacement: step 4, image 3 of 3
      • Slide off the first washer, the spring, and the second washer.
      Ask FixBot
    5. Foldable Grocery Cart Wheels Replacement: step 5, image 1 of 2 Foldable Grocery Cart Wheels Replacement: step 5, image 2 of 2
      • Take out the tattered wheel.
      • Make sure to keep the third washer on the axle.
      • Repeat steps 4 and 5 for the second wheel.
      Ask FixBot
    6. Foldable Grocery Cart Wheels Replacement: step 6, image 1 of 3 Foldable Grocery Cart Wheels Replacement: step 6, image 2 of 3 Foldable Grocery Cart Wheels Replacement: step 6, image 3 of 3
      • Take one of the new wheels and slide it on one side of the axle.
      Ask FixBot
    7. Foldable Grocery Cart Wheels Replacement: step 7, image 1 of 3 Foldable Grocery Cart Wheels Replacement: step 7, image 2 of 3 Foldable Grocery Cart Wheels Replacement: step 7, image 3 of 3
      • Slide on the first washer, the spring, and then the second washer back on the axle.
      • Repeat steps 6 and 7 for the second wheel.
      Ask FixBot
    8. Foldable Grocery Cart Wheels Replacement: step 8, image 1 of 3 Foldable Grocery Cart Wheels Replacement: step 8, image 2 of 3 Foldable Grocery Cart Wheels Replacement: step 8, image 3 of 3
      • Carefully place the front wheel axle with the new wheels in the side holes of the cart’s legs.
      Ask FixBot
    9. Foldable Grocery Cart Wheels Replacement: step 9, image 1 of 3 Foldable Grocery Cart Wheels Replacement: step 9, image 2 of 3 Foldable Grocery Cart Wheels Replacement: step 9, image 3 of 3
      • Insert the locking pins in each hole at both ends of the axle until the pins are halfway in the hole.
      • Using the hammer, tap the pins until they are entirely inside the hole.
      Ask FixBot
    10. Foldable Grocery Cart Wheels Replacement: step 10, image 1 of 3 Foldable Grocery Cart Wheels Replacement: step 10, image 2 of 3 Foldable Grocery Cart Wheels Replacement: step 10, image 3 of 3
      • Lastly, push the stoppers in each hole of the cart's legs.
      • Using the hammer, tap them in place.
      Ask FixBot
2 other people completed this guide.
Saba Aafreen
232 Reputation
1 Guide authored
3 Guide Comments
My back wheels need replacing. Can I use a different size because I’m having trouble finding the size I need. If they are a little bigger or smaller will it work. My wheels are non caster type wheels.
MoMac - Reply Share
Need to replace axle it's bent
Constance Butler - Reply Share
Do you have repair shop for non electronics like for carts? I am 69 with RA and darn it just not as strong as I used to be.
Debra Walker - Reply Share
Past 24 Hours: 18
Past 7 Days: 116
Past 30 Days: 485
All Time: 17,480
