Introduction
Use this guide to replace the rumble motors in a Flydigi Direwolf 2.
Remove the four 10 mm-long Phillips 10mm screws securing the rear case to the front case.
Lift the battery connector directly out of its socket.
Slide an opening pick underneath the battery to sever the adhesive securing it.
Gently lift the battery out.
Use your fingernails to lift and disconnect each of the two rumble motor connectors.
Lift the rumble motors directly out of their housings.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
