Flydigi Apex 5 Vibration Motors Replacement
  1. Flydigi Apex 5 Vibration Motors Replacement, Battery: step 1, image 1 of 2 Flydigi Apex 5 Vibration Motors Replacement, Battery: step 1, image 2 of 2
    • Orient the controller so that its back is facing you.
    • Apply firm downward pressure to remove both the M3 and M4 back paddles.
    Ask FixBot
  2. Flydigi Apex 5 Vibration Motors Replacement: step 2, image 1 of 3 Flydigi Apex 5 Vibration Motors Replacement: step 2, image 2 of 3 Flydigi Apex 5 Vibration Motors Replacement: step 2, image 3 of 3
    • Turn the controller over so its front faces you.
    • Remove the D-pad by firmly pulling it away from the body of the controller.
    Ask FixBot
  3. Flydigi Apex 5 Vibration Motors Replacement: step 3, image 1 of 3 Flydigi Apex 5 Vibration Motors Replacement: step 3, image 2 of 3 Flydigi Apex 5 Vibration Motors Replacement: step 3, image 3 of 3
    • Remove the clear, magnetically-adhered faceplate of the controller by firmly pulling it away from the body of the controller starting from the edge of the faceplate.
    Ask FixBot
  4. Flydigi Apex 5 Vibration Motors Replacement: step 4, image 1 of 3 Flydigi Apex 5 Vibration Motors Replacement: step 4, image 2 of 3 Flydigi Apex 5 Vibration Motors Replacement: step 4, image 3 of 3
    • Remove the small cover from the rear of the controller by pushing it upward.
    • Remove the two 5.8mm screws behind the battery cover using a Phillips #0 screwdriver.
    Ask FixBot
  5. Flydigi Apex 5 Vibration Motors Replacement: step 5, image 1 of 2 Flydigi Apex 5 Vibration Motors Replacement: step 5, image 2 of 2
    • Remove the six 10mm long screws from the front of the controller using a Torx T6 screwdriver.
    Ask FixBot
  6. Flydigi Apex 5 Vibration Motors Replacement: step 6, image 1 of 3 Flydigi Apex 5 Vibration Motors Replacement: step 6, image 2 of 3 Flydigi Apex 5 Vibration Motors Replacement: step 6, image 3 of 3
    • Insert the plastic opening tool between the top and bottom plastic controller molds, then pry until the two pieces separate.
    • Be careful not to fully separate the two pieces of the controller. There is a fragile ribbon cable connecting the two sides that must be carefully disconnected in the next step.
    Ask FixBot
  7. Flydigi Apex 5 Vibration Motors Replacement: step 7, image 1 of 3 Flydigi Apex 5 Vibration Motors Replacement: step 7, image 2 of 3 Flydigi Apex 5 Vibration Motors Replacement: step 7, image 3 of 3
    • Carefully remove the back paddle ribbon cable with the angled tweezers or spudger.
    Ask FixBot
  8. Flydigi Apex 5 Vibration Motors Replacement: step 8, image 1 of 3 Flydigi Apex 5 Vibration Motors Replacement: step 8, image 2 of 3 Flydigi Apex 5 Vibration Motors Replacement: step 8, image 3 of 3
    • Press a prong of each side of the angled tweezers under the lip of the power supply cable connector and pull the plastic connector out of its terminal.
    • Pull the power supply cable through the plastic cable guides.
    Ask FixBot
  9. Flydigi Apex 5 Vibration Motors Replacement: step 9, image 1 of 3 Flydigi Apex 5 Vibration Motors Replacement: step 9, image 2 of 3 Flydigi Apex 5 Vibration Motors Replacement: step 9, image 3 of 3
    • Optional: Drip isopropyl alcohol along the sides of the battery. Then rotate the controller to distribute the alcohol and dissolve the adhesive holding the battery to the mount
    • Pry up the battery with the plastic hook and pry tool.
    • Do not use sharp metal tools to pry the battery out. That action risks puncturing the battery.
    Ask FixBot
  10. Flydigi Apex 5 Vibration Motors Replacement, Vibration Motors: step 10, image 1 of 3 Flydigi Apex 5 Vibration Motors Replacement, Vibration Motors: step 10, image 2 of 3 Flydigi Apex 5 Vibration Motors Replacement, Vibration Motors: step 10, image 3 of 3
    • Press a prong of each side of the angled tweezers under the lip of the motor's power supply connector and pull the plastic connector out of its terminal.
    • Lift the motor directly upward out of its casing.
    Ask FixBot
  11. Flydigi Apex 5 Vibration Motors Replacement: step 11, image 1 of 3 Flydigi Apex 5 Vibration Motors Replacement: step 11, image 2 of 3 Flydigi Apex 5 Vibration Motors Replacement: step 11, image 3 of 3
    • Press a prong of each side of the curved tip tweezers under the lip of the motor's power supply connector and pull the plastic connector out of its terminal.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 38
All Time: 120
