Flydigi Apex 5 USB-C Daughterboard Replacement
    1. Flydigi Apex 5 USB-C Daughterboard Replacement, Battery: step 1, image 1 of 2 Flydigi Apex 5 USB-C Daughterboard Replacement, Battery: step 1, image 2 of 2
      • Orient the controller so that its back is facing you.
      • Apply firm downward pressure to remove both the M3 and M4 back paddles.
      Ask FixBot
    2. Flydigi Apex 5 USB-C Daughterboard Replacement: step 2, image 1 of 3 Flydigi Apex 5 USB-C Daughterboard Replacement: step 2, image 2 of 3 Flydigi Apex 5 USB-C Daughterboard Replacement: step 2, image 3 of 3
      • Turn the controller over so its front faces you.
      • Remove the D-pad by firmly pulling it away from the body of the controller.
      Ask FixBot
    3. Flydigi Apex 5 USB-C Daughterboard Replacement: step 3, image 1 of 3 Flydigi Apex 5 USB-C Daughterboard Replacement: step 3, image 2 of 3 Flydigi Apex 5 USB-C Daughterboard Replacement: step 3, image 3 of 3
      • Remove the clear, magnetically-adhered faceplate of the controller by firmly pulling it away from the body of the controller starting from the edge of the faceplate.
      Ask FixBot
    4. Flydigi Apex 5 USB-C Daughterboard Replacement: step 4, image 1 of 3 Flydigi Apex 5 USB-C Daughterboard Replacement: step 4, image 2 of 3 Flydigi Apex 5 USB-C Daughterboard Replacement: step 4, image 3 of 3
      • Remove the small cover from the rear of the controller by pushing it upward.
      • Remove the two 5.8mm screws behind the battery cover using a Phillips #0 screwdriver.
      Ask FixBot
    5. Flydigi Apex 5 USB-C Daughterboard Replacement: step 5, image 1 of 2 Flydigi Apex 5 USB-C Daughterboard Replacement: step 5, image 2 of 2
      • Remove the six 10mm long screws from the front of the controller using a Torx T6 screwdriver.
      Ask FixBot
    6. Flydigi Apex 5 USB-C Daughterboard Replacement: step 6, image 1 of 3 Flydigi Apex 5 USB-C Daughterboard Replacement: step 6, image 2 of 3 Flydigi Apex 5 USB-C Daughterboard Replacement: step 6, image 3 of 3
      • Insert the plastic opening tool between the top and bottom plastic controller molds, then pry until the two pieces separate.
      • Be careful not to fully separate the two pieces of the controller. There is a fragile ribbon cable connecting the two sides that must be carefully disconnected in the next step.
      Ask FixBot
    7. Flydigi Apex 5 USB-C Daughterboard Replacement: step 7, image 1 of 3 Flydigi Apex 5 USB-C Daughterboard Replacement: step 7, image 2 of 3 Flydigi Apex 5 USB-C Daughterboard Replacement: step 7, image 3 of 3
      • Carefully remove the back paddle ribbon cable with the angled tweezers or spudger.
      Ask FixBot
    8. Flydigi Apex 5 USB-C Daughterboard Replacement: step 8, image 1 of 3 Flydigi Apex 5 USB-C Daughterboard Replacement: step 8, image 2 of 3 Flydigi Apex 5 USB-C Daughterboard Replacement: step 8, image 3 of 3
      • Press a prong of each side of the angled tweezers under the lip of the power supply cable connector and pull the plastic connector out of its terminal.
      • Pull the power supply cable through the plastic cable guides.
      Ask FixBot
    9. Flydigi Apex 5 USB-C Daughterboard Replacement: step 9, image 1 of 3 Flydigi Apex 5 USB-C Daughterboard Replacement: step 9, image 2 of 3 Flydigi Apex 5 USB-C Daughterboard Replacement: step 9, image 3 of 3
      • Optional: Drip isopropyl alcohol along the sides of the battery. Then rotate the controller to distribute the alcohol and dissolve the adhesive holding the battery to the mount
      • Pry up the battery with the plastic hook and pry tool.
      • Do not use sharp metal tools to pry the battery out. That action risks puncturing the battery.
      Ask FixBot
    1. Flydigi Apex 5 USB-C Daughterboard Replacement, Vibration Motors: step 10, image 1 of 3 Flydigi Apex 5 USB-C Daughterboard Replacement, Vibration Motors: step 10, image 2 of 3 Flydigi Apex 5 USB-C Daughterboard Replacement, Vibration Motors: step 10, image 3 of 3
      • Press a prong of each side of the angled tweezers under the lip of the motor's power supply connector and pull the plastic connector out of its terminal.
      • Lift the motor directly upward out of its casing.
      Ask FixBot
    2. Flydigi Apex 5 USB-C Daughterboard Replacement: step 11, image 1 of 3 Flydigi Apex 5 USB-C Daughterboard Replacement: step 11, image 2 of 3 Flydigi Apex 5 USB-C Daughterboard Replacement: step 11, image 3 of 3
      • Press a prong of each side of the curved tip tweezers under the lip of the motor's power supply connector and pull the plastic connector out of its terminal.
      Ask FixBot
    1. Flydigi Apex 5 USB-C Daughterboard Replacement, USB-C Daughterboard: step 12, image 1 of 2 Flydigi Apex 5 USB-C Daughterboard Replacement, USB-C Daughterboard: step 12, image 2 of 2
      • Remove the USB-C faceplate by inserting the spudger as shown, pushing the spudger forward while twisting slightly.
      Ask FixBot
    2. Flydigi Apex 5 USB-C Daughterboard Replacement: step 13, image 1 of 3 Flydigi Apex 5 USB-C Daughterboard Replacement: step 13, image 2 of 3 Flydigi Apex 5 USB-C Daughterboard Replacement: step 13, image 3 of 3
      • Remove the two 10mm screws using a Phillips #0 screwdriver.
      • Remove the plastic battery mold by lifting away from the controller.
      Ask FixBot
    3. Flydigi Apex 5 USB-C Daughterboard Replacement: step 14, image 1 of 3 Flydigi Apex 5 USB-C Daughterboard Replacement: step 14, image 2 of 3 Flydigi Apex 5 USB-C Daughterboard Replacement: step 14, image 3 of 3
      • Remove the four 5mm screws using a Phillips #00 screwdriver.
      • Remove the two vibration motor housings by pulling away from the controller.
      Ask FixBot
    4. Flydigi Apex 5 USB-C Daughterboard Replacement: step 15, image 1 of 3 Flydigi Apex 5 USB-C Daughterboard Replacement: step 15, image 2 of 3 Flydigi Apex 5 USB-C Daughterboard Replacement: step 15, image 3 of 3
      • Remove the three 10mm screws using a Phillips #1 screwdriver.
      • Use your index finger to push on the left joystick, while also pulling on the motherboard with your other hand.
      Ask FixBot
    5. Flydigi Apex 5 USB-C Daughterboard Replacement: step 16, image 1 of 2 Flydigi Apex 5 USB-C Daughterboard Replacement: step 16, image 2 of 2
      • Use a pair of tweezers to push against the black latch to open the ribbon connector.
      • Use the pair of tweezers to gently pull the ribbon out of its connection.
      Ask FixBot
    6. Flydigi Apex 5 USB-C Daughterboard Replacement: step 17, image 1 of 2 Flydigi Apex 5 USB-C Daughterboard Replacement: step 17, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the two 5mm screws connecting the D-pad to the front of the controller.
      • Remove the black plastic cover holding the D-pad to the front of the controller.
      Ask FixBot
    7. Flydigi Apex 5 USB-C Daughterboard Replacement: step 18, image 1 of 3 Flydigi Apex 5 USB-C Daughterboard Replacement: step 18, image 2 of 3 Flydigi Apex 5 USB-C Daughterboard Replacement: step 18, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the two 7mm screws.
      • Remove the plastic bridge covering the USB-C daughterbord.
      • Pull the USB-C daughterboard away from the front of the controller.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 64
All Time: 225
