Flydigi Apex 5 Joystick Modules Replacement
    1. Flydigi Apex 5 Joystick Modules Replacement, Battery: step 1, image 1 of 2 Flydigi Apex 5 Joystick Modules Replacement, Battery: step 1, image 2 of 2
      • Orient the controller so that its back is facing you.
      • Apply firm downward pressure to remove both the M3 and M4 back paddles.
      Ask FixBot
    2. Flydigi Apex 5 Joystick Modules Replacement: step 2, image 1 of 3 Flydigi Apex 5 Joystick Modules Replacement: step 2, image 2 of 3 Flydigi Apex 5 Joystick Modules Replacement: step 2, image 3 of 3
      • Turn the controller over so its front faces you.
      • Remove the D-pad by firmly pulling it away from the body of the controller.
      Ask FixBot
    3. Flydigi Apex 5 Joystick Modules Replacement: step 3, image 1 of 3 Flydigi Apex 5 Joystick Modules Replacement: step 3, image 2 of 3 Flydigi Apex 5 Joystick Modules Replacement: step 3, image 3 of 3
      • Remove the clear, magnetically-adhered faceplate of the controller by firmly pulling it away from the body of the controller starting from the edge of the faceplate.
      Ask FixBot
    4. Flydigi Apex 5 Joystick Modules Replacement: step 4, image 1 of 3 Flydigi Apex 5 Joystick Modules Replacement: step 4, image 2 of 3 Flydigi Apex 5 Joystick Modules Replacement: step 4, image 3 of 3
      • Remove the small cover from the rear of the controller by pushing it upward.
      • Remove the two 5.8mm screws behind the battery cover using a Phillips #0 screwdriver.
      Ask FixBot
    5. Flydigi Apex 5 Joystick Modules Replacement: step 5, image 1 of 2 Flydigi Apex 5 Joystick Modules Replacement: step 5, image 2 of 2
      • Remove the six 10mm long screws from the front of the controller using a Torx T6 screwdriver.
      Ask FixBot
    6. Flydigi Apex 5 Joystick Modules Replacement: step 6, image 1 of 3 Flydigi Apex 5 Joystick Modules Replacement: step 6, image 2 of 3 Flydigi Apex 5 Joystick Modules Replacement: step 6, image 3 of 3
      • Insert the plastic opening tool between the top and bottom plastic controller molds, then pry until the two pieces separate.
      • Be careful not to fully separate the two pieces of the controller. There is a fragile ribbon cable connecting the two sides that must be carefully disconnected in the next step.
      Ask FixBot
    7. Flydigi Apex 5 Joystick Modules Replacement: step 7, image 1 of 3 Flydigi Apex 5 Joystick Modules Replacement: step 7, image 2 of 3 Flydigi Apex 5 Joystick Modules Replacement: step 7, image 3 of 3
      • Carefully remove the back paddle ribbon cable with the angled tweezers or spudger.
      Ask FixBot
    8. Flydigi Apex 5 Joystick Modules Replacement: step 8, image 1 of 3 Flydigi Apex 5 Joystick Modules Replacement: step 8, image 2 of 3 Flydigi Apex 5 Joystick Modules Replacement: step 8, image 3 of 3
      • Press a prong of each side of the angled tweezers under the lip of the power supply cable connector and pull the plastic connector out of its terminal.
      • Pull the power supply cable through the plastic cable guides.
      Ask FixBot
    9. Flydigi Apex 5 Joystick Modules Replacement: step 9, image 1 of 3 Flydigi Apex 5 Joystick Modules Replacement: step 9, image 2 of 3 Flydigi Apex 5 Joystick Modules Replacement: step 9, image 3 of 3
      • Optional: Drip isopropyl alcohol along the sides of the battery. Then rotate the controller to distribute the alcohol and dissolve the adhesive holding the battery to the mount
      • Pry up the battery with the plastic hook and pry tool.
      • Do not use sharp metal tools to pry the battery out. That action risks puncturing the battery.
      Ask FixBot
    1. Flydigi Apex 5 Joystick Modules Replacement, Vibration Motors: step 10, image 1 of 3 Flydigi Apex 5 Joystick Modules Replacement, Vibration Motors: step 10, image 2 of 3 Flydigi Apex 5 Joystick Modules Replacement, Vibration Motors: step 10, image 3 of 3
      • Press a prong of each side of the angled tweezers under the lip of the motor's power supply connector and pull the plastic connector out of its terminal.
      • Lift the motor directly upward out of its casing.
      Ask FixBot
    2. Flydigi Apex 5 Joystick Modules Replacement: step 11, image 1 of 3 Flydigi Apex 5 Joystick Modules Replacement: step 11, image 2 of 3 Flydigi Apex 5 Joystick Modules Replacement: step 11, image 3 of 3
      • Press a prong of each side of the curved tip tweezers under the lip of the motor's power supply connector and pull the plastic connector out of its terminal.
      Ask FixBot
    1. Flydigi Apex 5 Joystick Modules Replacement, Joystick Modules: step 12, image 1 of 2 Flydigi Apex 5 Joystick Modules Replacement, Joystick Modules: step 12, image 2 of 2
      • Remove the USB-C faceplate by inserting the spudger as shown, pushing the spudger forward while twisting slightly.
      Ask FixBot
    2. Flydigi Apex 5 Joystick Modules Replacement: step 13, image 1 of 3 Flydigi Apex 5 Joystick Modules Replacement: step 13, image 2 of 3 Flydigi Apex 5 Joystick Modules Replacement: step 13, image 3 of 3
      • Remove the two 1mm screws using a Phillips #0 screwdriver.
      • Remove the plastic battery mold by lifting away from the controller.
      Ask FixBot
    3. Flydigi Apex 5 Joystick Modules Replacement: step 14, image 1 of 3 Flydigi Apex 5 Joystick Modules Replacement: step 14, image 2 of 3 Flydigi Apex 5 Joystick Modules Replacement: step 14, image 3 of 3
      • Remove the four 5mm screws using a Phillips #00 screwdriver.
      • Remove the two vibration motor housings by pulling away from the controller.
      Ask FixBot
    4. Flydigi Apex 5 Joystick Modules Replacement: step 15, image 1 of 3 Flydigi Apex 5 Joystick Modules Replacement: step 15, image 2 of 3 Flydigi Apex 5 Joystick Modules Replacement: step 15, image 3 of 3
      • Remove the three 1mm screws using a Phillips #1 screwdriver.
      • Use your index finger to push on the left joystick, while also pulling on the motherboard with your other hand.
      Ask FixBot
    5. Flydigi Apex 5 Joystick Modules Replacement: step 16, image 1 of 3 Flydigi Apex 5 Joystick Modules Replacement: step 16, image 2 of 3 Flydigi Apex 5 Joystick Modules Replacement: step 16, image 3 of 3
      • Lift the latch that retains the right joystick flex cable.
      • Gently pull the cable away from the connector.
      Ask FixBot
    6. Flydigi Apex 5 Joystick Modules Replacement: step 17, image 1 of 3 Flydigi Apex 5 Joystick Modules Replacement: step 17, image 2 of 3 Flydigi Apex 5 Joystick Modules Replacement: step 17, image 3 of 3
      • Remove the four 4mm screws using a Phillips #00 screwdriver.
      • Using the palm of your opposite hand, hold the joystick against the motherboard while removing the screws to prevent the joystick from falling.
      Ask FixBot
    7. Flydigi Apex 5 Joystick Modules Replacement: step 18, image 1 of 3 Flydigi Apex 5 Joystick Modules Replacement: step 18, image 2 of 3 Flydigi Apex 5 Joystick Modules Replacement: step 18, image 3 of 3
      Ask FixBot
    8. Flydigi Apex 5 Joystick Modules Replacement: step 19, image 1 of 3 Flydigi Apex 5 Joystick Modules Replacement: step 19, image 2 of 3 Flydigi Apex 5 Joystick Modules Replacement: step 19, image 3 of 3
      • Remove the three 6mm screws using a Phillips #1 screwdriver.
      • On the other side of the board, use the spudger to separate the trigger module from the blue rotation sensor.
      • The motor in the trigger module is soldered onto the motherboard, so be cautious to not pull the module away too quickly.
      Ask FixBot
    9. Flydigi Apex 5 Joystick Modules Replacement: step 20, image 1 of 3 Flydigi Apex 5 Joystick Modules Replacement: step 20, image 2 of 3 Flydigi Apex 5 Joystick Modules Replacement: step 20, image 3 of 3
      • Hold the joystick to the motherboard to prevent the joystick from falling while removing the screws.
      Ask FixBot
      • After reassembling the controller with new joystick modules, you must recalibrate the joysticks. To do so, power on the controller and hold Start+Select+DPad up for 3 sec. Rotate the joysticks a few time and click them in to calibrate them and hit Start+Select+Dpad up again up to exit the calibration. Credit: @hoxigen
      Ask FixBot
NOTE: The flex cables have a line on the side opposing their contacts. This line indicates when the cable is properly seated in the connector. The line should be flush with or hidden by the connector.
2 Guide Comments
Amazing guide! One additional thing to mention is the calibration process after swapping the joysticks. You need to power on the controller and hold Start+Select+DPad up for 3 sec. Rotate the joysticks a few time and click them in to calibrate them and hit Start+Select+Dpad up again up to exit the calibration!
Christopher Nicolae - Reply Share
@hoxigen Thank you for pointing this out! I have added it as the last step of the guide. Thanks again for the info!
Kason Summers - Reply Share
Past 24 Hours: 20
Past 7 Days: 171
Past 30 Days: 608
All Time: 1,393
