FlySky FS-TH9X Antenna Wire Disconnected
    1. FlySky FS-TH9X Antenna Wire Disconnected, FlySky FS-TH9X Antenna Wire Disconnected: step 1, image 1 of 1
      • On the back of the remote, locate the antenna box labeled in red.
      Ask FixBot
    2. FlySky FS-TH9X Antenna Wire Disconnected: step 2, image 1 of 1
      • Unplug the wire that connects the antenna box to the controller.
      Ask FixBot
    3. FlySky FS-TH9X Antenna Wire Disconnected: step 3, image 1 of 1
      • On either side of the box, squeeze the clips and pull up to release the antenna box away from its socket.
      Ask FixBot
    4. FlySky FS-TH9X Antenna Wire Disconnected: step 4, image 1 of 1
      • Unscrew the two 2.5 mm Phillips #1 screws with a screwdriver and carefully remove the front plate.
      Ask FixBot
    5. FlySky FS-TH9X Antenna Wire Disconnected: step 5, image 1 of 1
      • Once you remove it, you will see a wire that is connected to the antenna, and a motherboard.
      Ask FixBot
    6. FlySky FS-TH9X Antenna Wire Disconnected: step 6, image 1 of 1
      • Locate the brass colored socket and the end of the wire and carefully connect them together.
      • It should click together.
      Ask FixBot
    7. FlySky FS-TH9X Antenna Wire Disconnected: step 7, image 1 of 1
      • Once connected assemble the box back together.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 28
All Time: 401
