Flute Head Cork Replacement
Views: 2.9K
View statistics:
Past 24 Hours:
8
Past 7 Days:
47
Past 30 Days:
161
All Time:
2,880
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
When flutes age, or are taken back and forth between places with different temperatures and humidities, the head joint cork can become shrunken and loose, which will not provide an adequate seal on the instrument. If the cork does become loose, a new one needs to be properly attached to the crown and screw device and pushed into the head joint of the flute. Without this cork, the instrument is not able to be played.
    1. Flute Head Cork Replacement, Head Cork: step 1, image 1 of 3 Flute Head Cork Replacement, Head Cork: step 1, image 2 of 3 Flute Head Cork Replacement, Head Cork: step 1, image 3 of 3
      • Unscrew the Flute Crown.
      • Use pliers to grip the protruding screw and pull out the old cork.
      Ask FixBot
    2. Flute Head Cork Replacement: step 2, image 1 of 3 Flute Head Cork Replacement: step 2, image 2 of 3 Flute Head Cork Replacement: step 2, image 3 of 3
      • Use a razor blade to cut the glue around the base of the screw set up.
      • Use a razor blade to cut the glue around the removable washer at the top of the cork.
      • Use a razor blade to make two lengthwise cuts on opposite sides of the cork.
      • Break the cork off of the screw.
      Ask FixBot
    3. Flute Head Cork Replacement: step 3, image 1 of 3 Flute Head Cork Replacement: step 3, image 2 of 3 Flute Head Cork Replacement: step 3, image 3 of 3
      • Use a small paintbrush to brush on a layer of contact cement onto the bottom of the new cork and the bottom of the screw set up.
      • Let contact cement sit for a few minutes and then slide the cork down onto the screw rod glue side first.
      Ask FixBot
    4. Flute Head Cork Replacement: step 4, image 1 of 3 Flute Head Cork Replacement: step 4, image 2 of 3 Flute Head Cork Replacement: step 4, image 3 of 3
      • Use a small paintbrush to paint a layer of polyurethane glue onto the top of the cork.
      • Do not use contact cement for this step because it will bind on contact and the washer needs to be screwed on.
      • Screw the washer onto the screw rod.
      • Wait for all the glues to dry.
      Ask FixBot
    5. Flute Head Cork Replacement: step 5, image 1 of 3 Flute Head Cork Replacement: step 5, image 2 of 3 Flute Head Cork Replacement: step 5, image 3 of 3
      • Drop the new cork and screw set up screw first into the bottom of the head joint. If the cork is the correct diameter you should be able to see it partially through the embouchure hole.
      • Flute head joints have a tapered diameter that is smaller at the top. This will not work if the cork is put into the top of the head joint.
      • Use the flute tuning rod to push the cork into the head joint until the tuning line at the bottom of the rod is in the middle of the embouchure hole.
      • If the cork is difficult to push down, paraffin wax can be rubbed onto the cork to help lubricate it.
      Ask FixBot
    6. Flute Head Cork Replacement: step 6, image 1 of 2 Flute Head Cork Replacement: step 6, image 2 of 2
      • Screw the crown back onto the screw set up and play the instrument to test that the new cork works.
      Ask FixBot
Finish Line
Zoe Bixler
133 Reputation
1 Guide authored
1 Guide Comment
The head joint cork assembly should never be pulled out the top of the head joint! Pulling it with pliers is a terrible idea! Attempting to do so will damage most flute professional head joints (it depends on the size of the cork plate). As a professional flute repair person I have seen a number of head joints with such damage. Because the head joint has a slight taper it must be pushed out the tenon end. Use a 5/8" wooden or plastic rod with a hole drilled a couple inches deep in one end to contain the threaded rod. Go to your repair person and ask for a demonstration.
Bradford - Reply Share
Past 24 Hours: 8
Past 7 Days: 47
Past 30 Days: 161
All Time: 2,880
