Fluke 77 Series III Battery Replacement
  1. Fluke 77 Series III Battery Replacement, Front Panel: step 1, image 1 of 1
    • Be sure any test leads are out and the multimeter is off before opening the device.
    • Turn the multimeter so it is display side down.
    • Lift up the back stand of the device by putting your thumb in the curved well at the bottom of the device, so you have access to the two covered screws below.
    Ask FixBot
  2. Fluke 77 Series III Battery Replacement: step 2, image 1 of 1
    • Use your Phillips #2 Screwdriver to remove the four black 21 mm Phillips #2 screws.
    Ask FixBot
  3. Fluke 77 Series III Battery Replacement: step 3, image 1 of 2 Fluke 77 Series III Battery Replacement: step 3, image 2 of 2
    • Turn the Fluke 77 Series III Multimeter back over so that it is display side up.
    • Pry the front panel from the back panel at the seam.
    • If the front panel does not come off easily, move a plastic opening tool along the seam until the panels separate completely.
    Ask FixBot
  4. Fluke 77 Series III Battery Replacement, Battery: step 4, image 1 of 2 Fluke 77 Series III Battery Replacement, Battery: step 4, image 2 of 2
    • When doing this next step, make sure to remove the battery slowly, so you don't damage the wires connecting the battery to the device.
    • Locate the 9V battery in the lower right corner of the device.
    • Pull the battery out of its terminal.
    Ask FixBot
  5. Fluke 77 Series III Battery Replacement: step 5, image 1 of 2 Fluke 77 Series III Battery Replacement: step 5, image 2 of 2
    • Only pull on the metal snaps and battery. Pulling the cords may damage them.
    • Detach the two metal snaps from the battery.
    Ask FixBot
5 other people completed this guide.
Jessica Bombardier Shaw
1,018 Reputation
7 Guides authored
Cal Poly, Team 2-10, Amido Winter 2014 Member of Cal Poly, Team 2-10, Amido Winter 2014
CPSU-AMIDO-W14S2G10
4 Members
10 Guides authored
1 Guide Comment
Easy to understand and all went well!
petruskewichw - Reply Share
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 88
All Time: 22,026
