Floor Pump Drive Hose Replacement
Views: 2.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
112
All Time:
2,868
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Over time, the hose on your steel floor drive pump may wear or puncture. Use this guide to install a new hose.
    1. Floor Pump Drive Hose Replacement, Drive Hose: step 1, image 1 of 3 Floor Pump Drive Hose Replacement, Drive Hose: step 1, image 2 of 3 Floor Pump Drive Hose Replacement, Drive Hose: step 1, image 3 of 3
      • Use a pair of pliers to loosen the hose pinch by turning it counterclockwise a couple of turns.
      • Continue to loosen the hose pinch by hand until it comes free from its threads.
      • Slide the hose pinch down the tube so that it does not interfere with removing the hose.
      Ask FixBot
    2. Floor Pump Drive Hose Replacement: step 2, image 1 of 3 Floor Pump Drive Hose Replacement: step 2, image 2 of 3 Floor Pump Drive Hose Replacement: step 2, image 3 of 3
      • Using a hobby knife, carefully slice a slit in the bottom of the hose to allow it to slide off.
      • Be careful and go slowly so as not to damage the nipple underneath.
      • Use a metal prying tool or flathead screwdriver to pry the hose up off of the nipple.
      • Remove the hose from the pump.
      Ask FixBot
    3. Floor Pump Drive Hose Replacement: step 3, image 1 of 2 Floor Pump Drive Hose Replacement: step 3, image 2 of 2
      • Slide the hose pinch off of the end of the old hose and onto the new hose.
      • Be sure that the threaded end of the hose pinch faces toward the open end of the new hose.
      Ask FixBot
    4. Floor Pump Drive Hose Replacement: step 4, image 1 of 3 Floor Pump Drive Hose Replacement: step 4, image 2 of 3 Floor Pump Drive Hose Replacement: step 4, image 3 of 3
      • Use a metal rod or screwdriver to widen the new hose so that it will fit over the nipple.
      • Slide the hose in place.
      • Push down on the hose clamp while twisting it clockwise to thread it in place.
      Ask FixBot
Finish Line
iRobot
1 Reputation
632 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 112
All Time: 2,868
