Flipper Zero NFC RFID board Replacement
      • Go to Main Menu > Settings > Power.
      • Select Power OFF.
      • Alternatively, you can press and hold the Back-button for around 10 seconds.
      • Confirm by pressing the Right-button.
      Ask FixBot
    1. Flipper Zero NFC RFID board Replacement, Remove the microSD card: step 2, image 1 of 1
      • Eject the microSD card by pressing it with your fingernail.
      Ask FixBot
    2. Flipper Zero NFC RFID board Replacement, Remove the screws: step 3, image 1 of 1
      Tool used on this step:
      Phillips #0 Screwdriver
      $5.49
      Buy
      • Use a PH0 screwdriver to unscrew the four long screws holding the back cover.
      • Be careful, the screws are quite easy to strip.
      Ask FixBot
    3. Flipper Zero NFC RFID board Replacement, Open the back cover: step 4, image 1 of 3 Flipper Zero NFC RFID board Replacement, Open the back cover: step 4, image 2 of 3 Flipper Zero NFC RFID board Replacement, Open the back cover: step 4, image 3 of 3
      • Press the middle of the top cover on both sides, one by one, to release the latches that hold the back cover in place.
      • Once the latches are released, you can remove the bottom cover.
      Ask FixBot
    1. Flipper Zero NFC RFID board Replacement, Seperate the chassis from the top cover: step 5, image 1 of 2 Flipper Zero NFC RFID board Replacement, Seperate the chassis from the top cover: step 5, image 2 of 2
      $5.49
      Buy
      • Use a PH0 screwdriver to unscrew the two short screws that are holding the chassis and top cover together.
      • Once the screws are removed, separate the chassis from the top cover.
      Ask FixBot
    2. Flipper Zero NFC RFID board Replacement, Disconnect the battery: step 6, image 1 of 1
      Spudger
      $3.99
      Buy
      • Disconnect the battery by carefully prying the connector with a Spudger and pulling it out.
      Ask FixBot
    1. Flipper Zero NFC RFID board Replacement, Disconnect the ribbon cables: step 7, image 1 of 2 Flipper Zero NFC RFID board Replacement, Disconnect the ribbon cables: step 7, image 2 of 2
      iFixit Opening Picks (Set of 6)
      $4.95
      Buy
      • Disconnect the large ribbon cable from the board. Use a plastic pick to lift the latch up to release the locks.
      • Once the connectors are unlocked, carefully pull out the ribbon cables.
      Ask FixBot
    2. Flipper Zero NFC RFID board Replacement, Remove the NFC RFID board: step 8, image 1 of 2 Flipper Zero NFC RFID board Replacement, Remove the NFC RFID board: step 8, image 2 of 2
      • To remove the NFC RFID board, release it from the latches in the sequence shown by pressing on the edge of the chassis near each latch.
      • Gently lift the NFC RFID board out of the chassis once all latches are released.
      Ask FixBot
Sebastian
33,565 Reputation
72 Guides authored
1 Guide Comment
I have a quick question- is there any place to buy the NFC board? I can't seem to find any place on the internet for it :c
msgraves - Reply Share
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 117
All Time: 3,637
