Up to 20% off select tools
Flipper Zero Display Replacement
Views: 29K
View statistics:
Past 24 Hours:
12
Past 7 Days:
100
Past 30 Days:
513
All Time:
28,993
Comments: 25
10 comments on steps, 15 guide comments.
Go to guide comments
Completed: 17
17 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Difficult
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
The Flipper Zero is a versatile multi-tool device that is widely used for hardware hacking, electronics prototyping, and security testing. One of its key features is its display, which allows users to interact with the device and view information. However, if the display on your Flipper Zero becomes damaged or stops working, it may be necessary to replace it.
Replacing the display on a Flipper Zero is a bit more involved than replacing some other components, as it requires desoldering the old display from the device's circuit board. However, with the right tools and some basic knowledge, it's a task that can be accomplished even by those with limited experience in electronics repair.
In this guide, we'll take you through the steps involved in replacing the display on your Flipper Zero, including how to desolder the old display. By following these steps, you can restore the functionality of your Flipper Zero and continue to use it for all your hardware hacking, electronics prototyping, and security testing needs. So, let's get started!
      • Go to Main Menu > Settings > Power.
      • Select Power OFF.
      • Alternatively, you can press and hold the Back-button for around 10 seconds.
      • Confirm by pressing the Right-button.
      Ask FixBot
    1. Flipper Zero Display Replacement, Remove the microSD card: step 2, image 1 of 1
      • Eject the microSD card by pressing it with your fingernail.
      Ask FixBot
    2. Flipper Zero Display Replacement, Remove the screws: step 3, image 1 of 1
      Tool used on this step:
      Phillips #0 Screwdriver
      $5.49
      Buy
      • Use a PH0 screwdriver to unscrew the four long screws holding the back cover.
      • Be careful, the screws are quite easy to strip.
      Ask FixBot
    3. Flipper Zero Display Replacement, Open the back cover: step 4, image 1 of 3 Flipper Zero Display Replacement, Open the back cover: step 4, image 2 of 3 Flipper Zero Display Replacement, Open the back cover: step 4, image 3 of 3
      • Press the middle of the top cover on both sides, one by one, to release the latches that hold the back cover in place.
      • Once the latches are released, you can remove the bottom cover.
      Ask FixBot
    1. Flipper Zero Display Replacement, Seperate the chassis from the top cover: step 5, image 1 of 2 Flipper Zero Display Replacement, Seperate the chassis from the top cover: step 5, image 2 of 2
      $5.49
      Buy
      • Use a PH0 screwdriver to unscrew the two short screws that are holding the chassis and top cover together.
      • Once the screws are removed, separate the chassis from the top cover.
      Ask FixBot
    2. Flipper Zero Display Replacement, Disconnect the battery: step 6, image 1 of 1
      Spudger
      $3.99
      Buy
      • Disconnect the battery by carefully prying the connector with a Spudger and pulling it out.
      Ask FixBot
    1. Flipper Zero Display Replacement, Disconnect the ribbon cable: step 7, image 1 of 1
      iFixit Opening Picks (Set of 6)
      $4.95
      Buy
      • Disconnect the large ribbon cable from the board. Use a plastic pick to lift the latch up to open the lock and carefully pull it out of the connector.
      Ask FixBot
    2. Flipper Zero Display Replacement, Release the battery chassis: step 8, image 1 of 2 Flipper Zero Display Replacement, Release the battery chassis: step 8, image 2 of 2
      • To release the battery chassis, lightly rock it back and forth while pulling the two parts apart.
      • Be sure to apply gentle and consistent pressure to avoid damaging the device.
      Ask FixBot
    3. Flipper Zero Display Replacement, Unscrew the the button chassis: step 9, image 1 of 1
      $5.49
      Buy
      • Unscrew the two short screws holding the button chassis using a PH0 screwdriver.
      Ask FixBot
    4. Flipper Zero Display Replacement, Seperate the button chassis: step 10, image 1 of 3 Flipper Zero Display Replacement, Seperate the button chassis: step 10, image 2 of 3 Flipper Zero Display Replacement, Seperate the button chassis: step 10, image 3 of 3
      • To seperate the button chassis and the board, press the latch on the side shown below and pull the chassis away from the board.
      Ask FixBot
    5. Flipper Zero Display Replacement, Disconnect the screen: step 11, image 1 of 2 Flipper Zero Display Replacement, Disconnect the screen: step 11, image 2 of 2
      $4.95
      Buy
      • Disconnect the screen ribbon cable from the board. Use a plastic pick to lift the latch up to open the lock and carefully pull it out of the connector.
      Ask FixBot
    6. Flipper Zero Display Replacement, Desolder the screen: step 12, image 1 of 1
      • To remove the screen you need to desolder two contacts.
      • See this guide on how to solder and desolder connections.
      Ask FixBot
Take your e-waste to anĀ R2 or e-Stewards certified recycler.
17 other people completed this guide.
Author
with
Sebastian
33,966 Reputation
72 Guides authored
15 Guide Comments
Everything worked fine following this guide. Thank you for the help. In my case was just the glass that was broken, so at the end, i didnt needed to desolder. Just removed the glass with the Plastic pick and worked perfectly. Thank you again for the help.
arthureldo - Reply Share
Where did you find a replacement glass?
Ben Durrant - Reply Share
The company behind FZ is not selling screen replacement (they promise they will do it in the future) but for now... So i don't what to think about this guide
Gusbill - Reply Share
@gusbill They are selling the replacements now
RetroFuse Electronics - Reply Share
Where can you get an LCD replacement (backlit)?
David Williams - Reply Share
Past 24 Hours: 12
Past 7 Days: 100
Past 30 Days: 513
All Time: 28,993
