Up to 20% off select tools
Flipper Zero Button Replacement
Views: 4.7K
View statistics:
Past 24 Hours:
5
Past 7 Days:
30
Past 30 Days:
153
All Time:
4,748
Comments: 5
3 comments on steps, 2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
Flipper Zero is a versatile multi-tool device that is widely used for hardware hacking, electronics prototyping, and security testing. One of its key features is its array of buttons, which allow users to interact with the device and perform various actions. However, like any mechanical component, the buttons on your Flipper Zero can eventually wear out or become damaged, leading to issues with functionality.
If you're experiencing issues with the buttons on your Flipper Zero, don't worry. Replacing the buttons is a relatively simple process that can be done with just a few tools and some basic knowledge. In this guide, we'll take you through the steps involved in replacing the buttons on your Flipper Zero, so you can continue to use this powerful tool for all your hardware hacking, electronics prototyping, and security testing needs.
      • Go to Main Menu > Settings > Power.
      • Select Power OFF.
      • Alternatively, you can press and hold the Back-button for around 10 seconds.
      • Confirm by pressing the Right-button.
      Ask FixBot
    1. Flipper Zero Button Replacement, Remove the microSD card: step 2, image 1 of 1
      • Eject the microSD card by pressing it with your fingernail.
      Ask FixBot
    2. Flipper Zero Button Replacement, Remove the screws: step 3, image 1 of 1
      Tool used on this step:
      Phillips #0 Screwdriver
      $5.49
      Buy
      • Use a PH0 screwdriver to unscrew the four long screws holding the back cover.
      • Be careful, the screws are quite easy to strip.
      Ask FixBot
    3. Flipper Zero Button Replacement, Open the back cover: step 4, image 1 of 3 Flipper Zero Button Replacement, Open the back cover: step 4, image 2 of 3 Flipper Zero Button Replacement, Open the back cover: step 4, image 3 of 3
      • Press the middle of the top cover on both sides, one by one, to release the latches that hold the back cover in place.
      • Once the latches are released, you can remove the bottom cover.
      Ask FixBot
    1. Flipper Zero Button Replacement, Seperate the chassis from the top cover: step 5, image 1 of 2 Flipper Zero Button Replacement, Seperate the chassis from the top cover: step 5, image 2 of 2
      $5.49
      Buy
      • Use a PH0 screwdriver to unscrew the two short screws that are holding the chassis and top cover together.
      • Once the screws are removed, separate the chassis from the top cover.
      Ask FixBot
    2. Flipper Zero Button Replacement, Disconnect the battery: step 6, image 1 of 1
      Spudger
      $3.99
      Buy
      • Disconnect the battery by carefully prying the connector with a Spudger and pulling it out.
      Ask FixBot
    1. Flipper Zero Button Replacement, Disconnect the ribbon cable: step 7, image 1 of 1
      iFixit Opening Picks (Set of 6)
      $4.95
      Buy
      • Disconnect the large ribbon cable from the board. Use a plastic pick to lift the latch up to open the lock and carefully pull it out of the connector.
      Ask FixBot
    2. Flipper Zero Button Replacement, Release the battery chassis: step 8, image 1 of 2 Flipper Zero Button Replacement, Release the battery chassis: step 8, image 2 of 2
      • To release the battery chassis, lightly rock it back and forth while pulling the two parts apart.
      • Be sure to apply gentle and consistent pressure to avoid damaging the device.
      Ask FixBot
    3. Flipper Zero Button Replacement, Remove the ribbon cable: step 9, image 1 of 2 Flipper Zero Button Replacement, Remove the ribbon cable: step 9, image 2 of 2
      $4.95
      Buy
      • Use a plastic pick to lift the latch up to unlock the connector and carefully remove the ribbon cable.
      Ask FixBot
    4. Flipper Zero Button Replacement, Unscrew the the button chassis: step 10, image 1 of 1
      $5.49
      Buy
      • Unscrew the two short screws holding the button chassis using a PH0 screwdriver.
      Ask FixBot
    5. Flipper Zero Button Replacement, Seperate the button chassis: step 11, image 1 of 3 Flipper Zero Button Replacement, Seperate the button chassis: step 11, image 2 of 3 Flipper Zero Button Replacement, Seperate the button chassis: step 11, image 3 of 3
      • To seperate the button chassis and the board, press the latch on the side shown below and pull the chassis away from the board.
      Ask FixBot
    6. Flipper Zero Button Replacement, The button layout: step 12, image 1 of 1
      • To remove the buttons you need to release the latches.
      • OK
      • D-pad
      • Back
      • The central button (OK) is removed after the navigation button (D-pad).
      Ask FixBot
    7. Flipper Zero Button Replacement, Unlatching the buttons: step 13, image 1 of 1
      Flathead 1.5 mm Screwdriver
      $1.99
      Buy
      Ask FixBot
    8. Flipper Zero Button Replacement, Remove the light diffuser: step 14, image 1 of 3 Flipper Zero Button Replacement, Remove the light diffuser: step 14, image 2 of 3 Flipper Zero Button Replacement, Remove the light diffuser: step 14, image 3 of 3
      • Use a flat head screwdriver to release the light diffuser from the chassis and pull it out.
      Ask FixBot
Author
with
Sebastian
33,966 Reputation
72 Guides authored
2 Guide Comments
I don't believe the top buttons on the plastic top layer are the problem. It's the physical button underneath the circuitboard.
Nutcheese99 - Reply Share
ifixit screwdrivers are too big for step 3 you must use wera PH0 or similar size
Aeris (AZ) - Reply Share
Past 24 Hours: 5
Past 7 Days: 30
Past 30 Days: 153
All Time: 4,748
