Flip-Flop Line Strap Replacement
Views: 30K
View statistics:
Past 24 Hours:
8
Past 7 Days:
50
Past 30 Days:
296
All Time:
29,601
Comments: 2
2 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 3 - 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
This guide will demonstrate how to fix the line strap on a flip-flop.
In Florida, most people own at least one pair of flip-flops. It’s a shoe that is worn almost anywhere; however, between the rainy weather and natural wear and tear of everyday use, one of the most common parts of a flip-flop destined to break is the line strap of the toe piece (between the big and second toe).
Why is this guide necessary?
This guide is necessary because discarded flip-flops are negatively impacting the environment – specifically the ocean.
In fact, dozens upon dozens of flip-flops wash ashore each year. Flip-flops that find their way into the ocean are hazardous, cause pollution, and interrupt the natural habitat of sea animals. Rather than continuously throw away something so common, we should seek to fix it to help support the environment.
Who will benefit from this guide?
This guide will be beneficial for all genders and ages and even for people in different states and countries. Unfortunately, thousands of people around the globe don’t have access to the resources we have here in the United States. A great way to support our planet and conserve resources is to fix our broken flip-flops and donate them to less-developed countries.
Where can I donate my flip-flops?
You can donate your flip-flops to a local charity organization, such as the Salvation Army or the American Red Cross.
Parts
Tools
    1. Flip-Flop Line Strap Replacement, Line Strap: step 1, image 1 of 1
      • Use the utility scissors to remove the tip of the broken line strap.
      • Try to remove as much of the broken tip as possible.
      Ask FixBot
    2. Flip-Flop Line Strap Replacement: step 2, image 1 of 1
      • Position one 8-inch zip tie underneath the strap line.
      • Head end of the zip tie.
      • Tail end of the zip tie.
      • You can use any color zip tie to match the color of your flip-flop.
      • Zip ties can be purchased from stores such as Walmart, Ace Hardware, and the Dollar Tree.
      Ask FixBot
    3. Flip-Flop Line Strap Replacement: step 3, image 1 of 1
      • Fold the zip tie so that the head end is on top of the line strap.
      Ask FixBot
    4. Flip-Flop Line Strap Replacement: step 4, image 1 of 1
      • Insert the tail end through the head end to make a loop.
      Ask FixBot
    5. Flip-Flop Line Strap Replacement: step 5, image 1 of 1
      • Tighten the loop by pulling on the tail end of the zip tie.
      • Make the loop approximately a half-inch.
      Ask FixBot
    6. Flip-Flop Line Strap Replacement: step 6, image 1 of 1
      • Cut off the extra zip tie material.
      Ask FixBot
    7. Flip-Flop Line Strap Replacement: step 7, image 1 of 1
      • Pass the metal flat washer through the second 8-inch zip tie.
      • 4.8mm metal flat washer.
      Ask FixBot
    8. Flip-Flop Line Strap Replacement: step 8, image 1 of 1
      • Pass the tail end through the hole on the bottom of the flip-flop.
      Ask FixBot
    9. Flip-Flop Line Strap Replacement: step 9, image 1 of 1
      • Pass the tail end through the loop of the first zip tie.
      Ask FixBot
    10. Flip-Flop Line Strap Replacement: step 10, image 1 of 2 Flip-Flop Line Strap Replacement: step 10, image 2 of 2
      • Return the tail end back through the hole.
      • Pass the tail end into the 4.8mm metal flat washer.
      • Turn the flip-flop on its side for a better view.
      Ask FixBot
    11. Flip-Flop Line Strap Replacement: step 11, image 1 of 1
      • Push the 4.8mm metal flat washer inside the hole of the flip-flop.
      Ask FixBot
    12. Flip-Flop Line Strap Replacement: step 12, image 1 of 1
      • Insert the tail end into the head end.
      Ask FixBot
    13. Flip-Flop Line Strap Replacement: step 13, image 1 of 2 Flip-Flop Line Strap Replacement: step 13, image 2 of 2
      • Adjust the length of the zip tie to create a snug fit between your toes.
      • Push the loop of the tail into the hole.
      • Pull on the tail end until you're satisfied with the length.
      • Turn the flip-flip over occasionally to check the length of the toe piece as needed.
      • Length of toe piece.
      • This step might take some trial and error.
      Ask FixBot
    14. Flip-Flop Line Strap Replacement: step 14, image 1 of 1
      • Push the head end into the hole of the flip-flop.
      • It's okay if the head end does not fit perfectly inside the hole. It will eventually fit deeper into the hole from walking.
      Ask FixBot
    15. Flip-Flop Line Strap Replacement: step 15, image 1 of 1
      Ask FixBot
    16. Flip-Flop Line Strap Replacement: step 16, image 1 of 1
      • Cut off about a 1-inch piece of heavy duty duct tape.
      • You can use any color heavy duty duct tape to match the color of your flip-flop.
      Ask FixBot
    17. Flip-Flop Line Strap Replacement: step 17, image 1 of 1
      • Wrap the 1-inch piece of heavy duty duct tape tightly around the toe piece of the flip-flop.
      • If you don't have heavy duty duct tape, use two pieces of regular duct tape.
      Ask FixBot
Your flip-flops are now restored! If you decide that you don't want them, please consider donating them to a local charity organization.
6 other people completed this guide.
2 Guide Comments
my faovert flip flops were riped by a cazey man at the swimming pool i saw him waht to do
Toby Robinson - Reply Share
Awesome. Thank you!
Windogalaz - Reply Share
Past 24 Hours: 8
Past 7 Days: 50
Past 30 Days: 296
All Time: 29,601
