Up to 20% off select tools
Flip Video Ultra USB Spring Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
91
All Time:
617
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will help you replace the USB spring should it need replacement. The only tool needed is the Phillips #1 Screwdriver. It should only take 10 minutes.
    1. Flip Video Ultra USB Spring Replacement, USB spring: step 1, image 1 of 1
      • Unlock the battery cover by sliding the switch to the unlock position.
      Ask FixBot
    2. Flip Video Ultra USB Spring Replacement: step 2, image 1 of 1
      • Remove the battery cover by sliding it down the camera.
      Ask FixBot
    3. Flip Video Ultra USB Spring Replacement: step 3, image 1 of 1
      • Remove the batteries
      Ask FixBot
    4. Flip Video Ultra USB Spring Replacement: step 4, image 1 of 1
      • Slide the black upper casing off from the device.
      Ask FixBot
    5. Flip Video Ultra USB Spring Replacement: step 5, image 1 of 2 Flip Video Ultra USB Spring Replacement: step 5, image 2 of 2
      • Remove the six 1mm screws from the back and upper casing with the Phillips Head screwdriver.
      Ask FixBot
    6. Flip Video Ultra USB Spring Replacement: step 6, image 1 of 1
      • Remove the top casing from the bottom to reveal the inner circuit board.
      Ask FixBot
    7. Flip Video Ultra USB Spring Replacement: step 7, image 1 of 2 Flip Video Ultra USB Spring Replacement: step 7, image 2 of 2
      • When removing the back panel, the rubber buttons will become loose and likely fall off the board. This is normal and can easily placed back on the board once finished.
      • Remove the six 1mm screws with the 1 Phillips head screwdriver.
      Ask FixBot
    8. Flip Video Ultra USB Spring Replacement: step 8, image 1 of 1
      • Gently separate the circuit board from the casing.
      Ask FixBot
    9. Flip Video Ultra USB Spring Replacement: step 9, image 1 of 1
      • Using the Phillips head screwdriver, disconnect spring from the plastic nubs.
      Ask FixBot
Author
with
Nathaniel Ruf
514 Reputation
5 Guides authored
UMass Dartmouth, Team 5-7, Martin Fall 2016 Member of UMass Dartmouth, Team 5-7, Martin Fall 2016
UMASSD-MARTIN-F16S5G7
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 91
All Time: 617
