Up to 20% off select tools
Flip Video LCD Screen
Views: 6.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
26
Past 30 Days:
111
All Time:
6,089
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This guide will show you how to disassemble your flip video and replace the LCD screen.
    1. Flip Video LCD Screen, Outer Shell: step 1, image 1 of 2 Flip Video LCD Screen, Outer Shell: step 1, image 2 of 2
      • Turn off the device and take the batteries out.
      • Remove metal sticker under the LCD screen with a spudger.
      • This may require a large force to pry off the glued sticker.
      Ask FixBot
    2. Flip Video LCD Screen: step 2, image 1 of 1
      • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
      Ask FixBot
    3. Flip Video LCD Screen: step 3, image 1 of 2 Flip Video LCD Screen: step 3, image 2 of 2
      • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
      Ask FixBot
    4. Flip Video LCD Screen: step 4, image 1 of 1
      • Open battery door. This can be done by gently depressing and sliding the battery down downward.
      Ask FixBot
    5. Flip Video LCD Screen: step 5, image 1 of 1
      • Use the spudger to separate outer shells.
      • The spudger must be inserted between the shell halves to pry the edges apart.
      • Slowly work around the outside to separate the halves.
      Ask FixBot
    1. Flip Video LCD Screen, Circuit Board: step 6, image 1 of 1
      • Remove the 3 5mm screws securing the circuit board to the front shell with the #00 Phillips screwdriver.
      Ask FixBot
    2. Flip Video LCD Screen: step 7, image 1 of 1
      • Slowly lift the left side of the circuit board.
      • Do not attempt to remove the circuit board completely yet. It is still connected to the device.
      Ask FixBot
    3. Flip Video LCD Screen: step 8, image 1 of 1
      • Disconnect the USB port cable from the back side of the circuit board.
      Ask FixBot
    4. Flip Video LCD Screen: step 9, image 1 of 1
      • Slide out the battery contacts.
      • Battery contacts
      • Slot where battery contacts were located
      Ask FixBot
    1. Flip Video LCD Screen, LCD Screen: step 10, image 1 of 1
      • With the LCD screen facing away from you, remove the 2 bronze 3 mm screws securing the LCD using the #00 Phillips screwdriver.
      Ask FixBot
    2. Flip Video LCD Screen: step 11, image 1 of 1
      • Flip over the circuit board and unlock the two black tabs on the ribbon connector by sliding them upwards.
      Ask FixBot
    3. Flip Video LCD Screen: step 12, image 1 of 1
      • Gently pull out ribbon cable.
      • If the ribbon cable does not come out easily you may not have fully unlocked the ribbon cable connector in the previous step.
      • The LCD screen is now removed and can be replaced.
      Ask FixBot
Author
with
Elizabeth
100 Reputation
6 Guides authored
Cal Poly, Team 26-21, Regan Spring 2010 Member of Cal Poly, Team 26-21, Regan Spring 2010
CPSU-REGAN-S10S26G21
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 26
Past 30 Days: 111
All Time: 6,089
