Flip Video Directional button replacement or cleaning
    1. Flip Video Directional button replacement or cleaning, Outer Shell: step 1, image 1 of 2 Flip Video Directional button replacement or cleaning, Outer Shell: step 1, image 2 of 2
      • Turn off the device and take the batteries out.
      • Remove metal sticker under the LCD screen with a spudger.
      • This may require a large force to pry off the glued sticker.
      Ask FixBot
    2. Flip Video Directional button replacement or cleaning: step 2, image 1 of 1
      • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
      Ask FixBot
    3. Flip Video Directional button replacement or cleaning: step 3, image 1 of 2 Flip Video Directional button replacement or cleaning: step 3, image 2 of 2
      • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
      Ask FixBot
    4. Flip Video Directional button replacement or cleaning: step 4, image 1 of 1
      • Open battery door. This can be done by gently depressing and sliding the battery down downward.
      Ask FixBot
    5. Flip Video Directional button replacement or cleaning: step 5, image 1 of 1
      • Use the spudger to separate outer shells.
      • The spudger must be inserted between the shell halves to pry the edges apart.
      • Slowly work around the outside to separate the halves.
      Ask FixBot
    1. Flip Video Directional button replacement or cleaning, Flip Video Directional button replacement or cleaning: step 6, image 1 of 1
      • Remove the silicone directional pad insert from the front outer shell.
      • Clean the buttons with soapy water before reassembling the device.
      • Make sure it is completely dry before placing back into the device.
      Ask FixBot
Elizabeth
100 Reputation
6 Guides authored
Cal Poly, Team 26-21, Regan Spring 2010 Member of Cal Poly, Team 26-21, Regan Spring 2010
CPSU-REGAN-S10S26G21
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 36
All Time: 2,396
