Flashforge Finder 2 Fan Cleaning or Replacement
    1. Flashforge Finder 2 Fan Cleaning or Replacement, Work safely: step 1, image 1 of 1
      • Shut down the back switch and disconnect the printer power supply
      • If used recently wait for the extruder to cool down
      Ask FixBot
    2. Flashforge Finder 2 Fan Cleaning or Replacement, Remove extruder cover: step 2, image 1 of 3 Flashforge Finder 2 Fan Cleaning or Replacement, Remove extruder cover: step 2, image 2 of 3 Flashforge Finder 2 Fan Cleaning or Replacement, Remove extruder cover: step 2, image 3 of 3
      • Remove the three screws on the extruder top with a 2.5 Allen key or an appropriate screwdriver bit
      • Gently lift up the extruder cover
      • Pay attention to the flat cable while lifting the cover
      Ask FixBot
    3. Flashforge Finder 2 Fan Cleaning or Replacement, Disconnect the fan: step 3, image 1 of 1
      • Using a spudger, disconnect the fan connector
      • Route the cable to free it
      Ask FixBot
    4. Flashforge Finder 2 Fan Cleaning or Replacement, Unscrew the fan: step 4, image 1 of 2 Flashforge Finder 2 Fan Cleaning or Replacement, Unscrew the fan: step 4, image 2 of 2
      • Remove the two Phillips screw holding the fan
      Ask FixBot
    5. Flashforge Finder 2 Fan Cleaning or Replacement, (Optional) Disassemble the fan: step 5, image 1 of 2 Flashforge Finder 2 Fan Cleaning or Replacement, (Optional) Disassemble the fan: step 5, image 2 of 2
      • The fan can now be removed from the extruder. If you need to replace it, just follow the steps in reverse order with the new fan
      • If you are cleaning the fan, release the three clips holding it together with a spudger
      Ask FixBot
    6. Flashforge Finder 2 Fan Cleaning or Replacement, Clean the fan: step 6, image 1 of 1
      • Using compressed air and a brush, clean the fan from dust and debris
      Ask FixBot
dinoo_fixit
1,801 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 29
All Time: 412
