Up to 20% off select tools
Flashforge 5M Cold Pull Maintenance
View statistics:
Past 24 Hours:
7
Past 7 Days:
34
Past 30 Days:
140
All Time:
276
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 3 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Adventurer 5M Cold Pull Procedure to help clean the nozzle without removal of the nozzle
    1. Flashforge 5M Cold Pull Maintenance, Heat up the nozzle: step 1, image 1 of 1
      • Start by cutting and removing any current filament that is loaded inside the nozzle. Then heat the nozzle by pressing the nozzle temperature icon, a popup should appear asking you how hot you would like the nozzle. Heat up to 230 degrees or higher.
      • The heat bed does not need to be heat up.
      Ask FixBot
    2. Flashforge 5M Cold Pull Maintenance, Remove the PTFE Tube: step 2, image 1 of 1
      • Removing the PTFE tube is simply pulling it off.
      Ask FixBot
    3. Flashforge 5M Cold Pull Maintenance, Cleaning the nozzle: step 3, image 1 of 1
      • Grab unused filament and slowly push it down the nozzle.
      • Once you think you have pushed far enough(Ideally untill filament starts to ooze out of the nozzle) yank it out with a swift movement to grab any dust
      • Do this as many times as desired(5-7 times is ideal, but for more thorough cleaning, 9-12 or more is needed)
      Ask FixBot
    4. Flashforge 5M Cold Pull Maintenance: step 4, image 1 of 1
      • Put back the PTFE tube, and done.
      Ask FixBot
When done, always make sure you set the nozzle temperature back to 0.
Wyatt
175 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 34
Past 30 Days: 140
All Time: 276
