Up to 20% off select tools
Flash Motherboard
Views: 4.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
113
All Time:
4,841
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Difficult
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Flash Motherboard
Tools
Introduction
Go to step 1 ↓
If your flash settings are set correctly but your camera does not flash, you will need to replace the flash motherboard. First, you will need to remove the front and back covers. Once that is complete, you will have access to the flash motherboard.
    1. Flash Motherboard, Front and Back Covers: step 1, image 1 of 3 Flash Motherboard, Front and Back Covers: step 1, image 2 of 3 Flash Motherboard, Front and Back Covers: step 1, image 3 of 3
      • Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
      • There are 2 screws on the left side (when looking at the front of the camera).
      • There are 3 screws on the bottom
      • There is 1 screw on the right side
      Ask FixBot
    2. Flash Motherboard: step 2, image 1 of 1
      • Turn to the bottom of the camera.
      • Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
      Ask FixBot
    3. Flash Motherboard: step 3, image 1 of 1
      • This is what the SD card/battery compartment looks like when opened.
      • Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
      Ask FixBot
    4. Flash Motherboard: step 4, image 1 of 2 Flash Motherboard: step 4, image 2 of 2
      • Gently remove the front cover away from the camera body.
      • Tip: Start by loosening the teeth on the left side of the camera next to the battery compartment.
      Ask FixBot
    5. Flash Motherboard: step 5, image 1 of 1
      • The camera should look like this once the front cover is removed.
      Ask FixBot
    6. Flash Motherboard: step 6, image 1 of 3 Flash Motherboard: step 6, image 2 of 3 Flash Motherboard: step 6, image 3 of 3
      Tool used on this step:
      Buy
      • Start from the battery compartment and remove the back cover.
      • Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
      • Remove the connecting ribbon from the body of the camera using a pair of tweezers.
      Ask FixBot
    7. Flash Motherboard: step 7, image 1 of 1
      • Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
      Ask FixBot
    1. Flash Motherboard, Flash Motherboard: step 8, image 1 of 1
      • Turn to the front of the camera.
      • Find the flash motherboard located behind the flash assembly on the top right.
      Ask FixBot
    2. Flash Motherboard: step 9, image 1 of 1
      • Use a soldering iron and a desoldering wick to disconnect the wires from the marked locations.
      • Once the cables are disconnected, you are now ready to install a new motherboard.
      Ask FixBot
4 other people completed this guide.
Author
with
Jakub
134 Reputation
2 Guides authored
Cal Poly, Team 8-6, Regan Spring 2011 Member of Cal Poly, Team 8-6, Regan Spring 2011
CPSU-REGAN-S11S8G6
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 113
All Time: 4,841
