Up to 20% off select tools
Fixing the Error Code 165-6596
Views: 4.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
23
Past 30 Days:
130
All Time:
4,111
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 15 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
This error always occurs on any amiibo compatible game/software (except for Mario Kart 8 if not on the amiibo Mii suits section), due to the NFC board being either disconnected from the GamePad or completely fried. In this tutorial, you will reseat the NFC board back to where it belongs.
Credit: Mod and Pop Thrift (the original video)
    1. Fixing the Error Code 165-6596, Removing the stylus and battery lid: step 1, image 1 of 2 Fixing the Error Code 165-6596, Removing the stylus and battery lid: step 1, image 2 of 2
      • Remove the stylus. This in order to correctly remove the back cover
      • Unscrew the battery lid with the P00 Philps Screwdriver.
      Ask FixBot
    2. Fixing the Error Code 165-6596, Removing the battery: step 2, image 1 of 1
      • After removing the lid, carefully remove the cable connecting the battery to the motherboard and lift up the battery
      Ask FixBot
    3. Fixing the Error Code 165-6596, Removing the back cover: step 3, image 1 of 1
      • Remove the screw covers with the pick and use the Tri-wing Screwdriver to unscrew the remaining screws around the GamePad.
      • Lift up the back cover
      • Lift up gently, as the rumble motor is attached
      Ask FixBot
    4. Fixing the Error Code 165-6596, Reseating the NFC board: step 4, image 1 of 1
      • I have put a circle around the correct placement of the NFC board. This is how it should look like.
      • If the NFC board is detached, gently reseat it back to where it was.
      • If the NFC board seated correctly, gently remove and gently reseat it.
      Ask FixBot
To reassemble your device, follow these instructions from Step 3 in reverse order. If the problem persists (even after multiple attempts), it might be time to order a replacement part.
2 other people completed this guide.
Author
with
ChrisLord9
332 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 130
All Time: 4,111
