Fixing a Small Animal Cage Ladder
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
80
All Time:
908
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
I am going to create a guide on how to fix a small animal ladder. This ladder is about 12.5 inches in length and 4.5 inches in width. This ladder consists of small cylinders resembling stairs that are attached to each other with enough stability to hold a small animal. The issue with this item is that the rope holding these small cylinders making the ladder continue to fall off and detach from the rest of the pieces, leaving wood hanging in two separate strands no longer resembling a ladder. There is rope holding these cylinders creating the ladder together and it teared over time and use. To avoid going to the store and having to buy a new one I want to just fix the issue where it lies. The idea is to get a new rope from a repair shop such as Lowes or Home Depot and remove the old rope from the ladder and replacing it with the new one.
    1. Fixing a Small Animal Cage Ladder, Replacing the Rope for a Small Animal Cage Ladder: step 1, image 1 of 1
      • Take your ladder out of the pet’s cage and lay it out to clearly assess the damage.
      Ask FixBot
    2. Fixing a Small Animal Cage Ladder: step 2, image 1 of 3 Fixing a Small Animal Cage Ladder: step 2, image 2 of 3 Fixing a Small Animal Cage Ladder: step 2, image 3 of 3
      • Gather your supplies for the fix (ie: new rope, scissors, ruler, sewing kit, clips). These items will be used to fix the small ladder.
      Ask FixBot
    3. Fixing a Small Animal Cage Ladder: step 3, image 1 of 2 Fixing a Small Animal Cage Ladder: step 3, image 2 of 2
      • Cut the old rope in the ladder with scissors and pull it out of the cylindrical wood pieces.
      • Make sure the knots at the ends of the rope are cut. This will enable you to pull the rope out easily.
      Ask FixBot
    4. Fixing a Small Animal Cage Ladder: step 4, image 1 of 1
      • Measure your new rope to the length of the ladder using a ruler.
      Ask FixBot
    5. Fixing a Small Animal Cage Ladder: step 5, image 1 of 1
      • Begin pushing rope through the individual holes in the wood pieces (use a sewing kit if necessary).
      • If there is the need to use a sewing kit to drag the rope through the wood here is how to do so: Push the needle through the end of the rope and tie a knot around the rope. Once you are finished with this, push the needle through the rope holes and then sew the rope through the individual pieces.
      Ask FixBot
    6. Fixing a Small Animal Cage Ladder: step 6, image 1 of 1
      • Once all the rope has connected the wood into a ladder, tie knots at each end to keep the pieces together.
      Ask FixBot
    7. Fixing a Small Animal Cage Ladder: step 7, image 1 of 1
      • Add clips to the ends of the rope and attach to the small animal cage.
      • If the clips cannot attach to the rope, tie the rope around the clips.
      Ask FixBot
Katrina Hartmann
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 80
All Time: 908
