Community-Contributed Guide
Tools
Plastic bagsOptional
Introduction
Go to step 1 ↓Because the SD1400 IS is so old, its mode switch can get stuck in the video position. When that happens, the camera records only video, and no menu setting will switch it back to photo mode. This could also happen if the camera gets dropped or jammed in some way. Until now, there hasn’t been a clear guide showing where the switch sits inside the camera or how to reach it.
This guide shows you how to open the camera, find the switch, and if it is broken like mine was, figure out what to do. If you can get a replacement part, the same steps should let you install it. [Note: With this fix, the camera takes photos only, and video recording is no longer available until you manually switch it back and vice versa. It is a good temporary fix.]
The guide has a few steps. Every step includes photos so you can follow along even if you don’t read English well.
Difficulty: Moderate
Time required: 15 to 45 minutes
Get the camera and see if any screws are stripped. Make sure you have removed any batteries in the camera.
Here is another angle. Once you are able to slide the black button/type of lever, you should be done. I used a toothpick and safety pin just because the safety pin was easier to handle inside the camera.
Remember to be gentle and don't push/try too hard. Slow and steady will get it fixed much safer.
If your Canon PowerShot SD1400 IS (also sold as the IXUS 130 / IXY 400F) only records video and won’t switch back to photo mode, this guide shows you how to open the camera, find the mode switch, and lock the camera into photo mode when a replacement part isn’t available.
