Fixed Gear Bike Chainring Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
43
Past 30 Days:
198
All Time:
1,367
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Do you also own a fixed gear or a track bike? Fixed-gear bikes generally have fewer components and parts than any other bikes. A chain ring plays a vital role in the drive train and is attached to the crankset. As the bike ages, and the more miles you put on your fixie, the higher the chances of the chainring getting worn down. Replacing a worn-out chainring benefits the quality of your bike rides and drivetrain longevity.
    1. Fixed Gear Bike Chainring Replacement, Chainring: step 1, image 1 of 2 Fixed Gear Bike Chainring Replacement, Chainring: step 1, image 2 of 2
      • Slightly loosen the two rear nuts with a 15 mm wrench to give the chain slack.
      • Remove the chain from the worn out chain ring.
      Ask FixBot
    2. Fixed Gear Bike Chainring Replacement: step 2, image 1 of 2 Fixed Gear Bike Chainring Replacement: step 2, image 2 of 2
      • Undo all five bolts attached to the crank arm with a hex tool.
      Ask FixBot
    3. Fixed Gear Bike Chainring Replacement: step 3, image 1 of 2 Fixed Gear Bike Chainring Replacement: step 3, image 2 of 2
      • Take the chain ring off through the crank arm of the pedal and swap the chainring of your choice.
      • Keep all five bolts in the same area to prevent losing them.
      • When bolts appear to be rusty, I recommend replacing them with a new set of bolts for the longevity of the drivetrain.
      Ask FixBot
    4. Fixed Gear Bike Chainring Replacement: step 4, image 1 of 1
      • Line up the chainring’s hole to the crankset and tighten all five bolts to hold the chainring in place.
      Ask FixBot
    5. Fixed Gear Bike Chainring Replacement: step 5, image 1 of 1
      • Lastly, attach the chain back to the new chainring.
      • Before tightening the two rear nuts back together, ensure the wheel is centered and not touching the rear bike frame.
      Ask FixBot
Finish Line
aljndro__
121 Reputation
1 Guide authored
CSU Los Angeles, Team 1-1, Briggs Fall 2023 Member of CSU Los Angeles, Team 1-1, Briggs Fall 2023
CSULA-BRIGGS-F23S1G1
6 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 43
Past 30 Days: 198
All Time: 1,367
