Fix the MyFirst Camera Insta 2 charge issue
Views: 1.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
79
All Time:
1,091
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 hour
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
Introduction
Go to step 1 ↓
If the device cannot charge and is boot-looping, it is possible to force it to charge correctly by unplugging screen and speaker.
    1. Fix the MyFirst Camera Insta 2 charge issue, Prepare teardown: step 1, image 1 of 3 Fix the MyFirst Camera Insta 2 charge issue, Prepare teardown: step 1, image 2 of 3 Fix the MyFirst Camera Insta 2 charge issue, Prepare teardown: step 1, image 3 of 3
      • Remove SD card, carry strap and paper cartridge
      Ask FixBot
    2. Fix the MyFirst Camera Insta 2 charge issue, Lift the front panel: step 2, image 1 of 2 Fix the MyFirst Camera Insta 2 charge issue, Lift the front panel: step 2, image 2 of 2
      • Remove the front panel
      • The panel is simply clipped and can be declipped easily by using a mediator as lever
      Ask FixBot
    3. Fix the MyFirst Camera Insta 2 charge issue, Unscrew front panel: step 3, image 1 of 2 Fix the MyFirst Camera Insta 2 charge issue, Unscrew front panel: step 3, image 2 of 2
      • The toy is closed by 5 Philips-head screws, size 0
      • Unscrew them all and open the product
      Ask FixBot
    4. Fix the MyFirst Camera Insta 2 charge issue, Remove the cartridge-holding piece: step 4, image 1 of 3 Fix the MyFirst Camera Insta 2 charge issue, Remove the cartridge-holding piece: step 4, image 2 of 3 Fix the MyFirst Camera Insta 2 charge issue, Remove the cartridge-holding piece: step 4, image 3 of 3
      • The white piece is held by 4 Philips-head screws
      • Unscrew the three screws you can already access
      • Unscrew the selfie camera, held by two smaller screws
      • Under the camera, unscrew the forth screw holding the piece
      Ask FixBot
    5. Fix the MyFirst Camera Insta 2 charge issue, Disconnect the screen: step 5, image 1 of 1
      • Remove the glue around the screen connector
      • Disconnect by lifting the connector clip upward
      Ask FixBot
    6. Fix the MyFirst Camera Insta 2 charge issue, Unscrew the PCB: step 6, image 1 of 2 Fix the MyFirst Camera Insta 2 charge issue, Unscrew the PCB: step 6, image 2 of 2
      • The board is held by the 4 previously removed screws, plus another screw close to USB connector
      • Once all those are removed and the screen is disconnected, pull the card from its compartment by sliding it on the side opposite to USB connector
      Ask FixBot
    7. Fix the MyFirst Camera Insta 2 charge issue, Teardown view: step 7, image 1 of 3 Fix the MyFirst Camera Insta 2 charge issue, Teardown view: step 7, image 2 of 3 Fix the MyFirst Camera Insta 2 charge issue, Teardown view: step 7, image 3 of 3
      • Unknown microcontrolleur, QFP80 package , with reference "2104G-91"
      • Princeton Technology PT5139-HT motor driver
      • Syncrown PT48D 2-inch thermal printer
      • Thinksum 123050 7.4V 750mAh li-ion battery
      • Screen, speaker, two photo modules
      Ask FixBot
    1. Fix the MyFirst Camera Insta 2 charge issue, Fix the MyFirst Camera Insta 2 charge issue: step 8, image 1 of 1
      • Once the toy is disassembled, replug the battery only and let it charge, with a micro-USB cable
      • Unplug the battery once again before remounting the device
      Ask FixBot
To reassemble your device, follow the unmounting instructions in reverse order.
Special thanks to these translators:
fr en
100%
Eve Redero is helping us fix the world! Want to contribute?
Start translating ›
Eve Redero
3,414 Reputation
11 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 79
All Time: 1,091
