Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Tools
Spudger4.9
Introduction
Go to step 1 ↓This guide shows how to fix the clouding effect (bright spots on the display).
Lay the TV face down on a table so that the stand is not touching the table and the TV is level.
Unscrew the two Phillips screws from the base and pull it down so that it can be loosened.
Unscrew the six Phillips screws from the back cover.
Now slide a pick between the back cover and the frame and gradually separate them until all sides are loose.
Take the IR receiver out of its place and disconnect the cable from the mainboard.
Take the speakers out of their place and disconnect the cables.
Unscrew the 8 Phillips screws from the two metal covers on the bottom of the TV.
Now fold up the two black brackets on the boards you just uncovered and take out the flex cables.
Unscrew the 18 Phillips screws on the sides of the TV.
Turn the TV over.
Carefully remove the frame around the display.
Use several suction cups to remove the LCD display from the frame.
Remove the 2nd frame with e.g. a spudger by releasing the small clips on the sides.
Glue the scattered lenses back on, e.g. with superglue.
Congratulations! You managed to fix your TV!
Work the steps in reverse order to reassemble your device.
Special thanks to these translators:
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
