Introduction
Easy fix if the top plate is loose allowing the scales to rotate slightly.
Using a 2.5 mm hex, remove the two screws visible on the bottom of the scales. No need to remove any stickers or bumpers.
Tighten these two screws using the same 2.5 mm hex as before. Make sure the load cell is straight and aligned with the mount below.
