Fix 1kHz noise on a USB microphone
  1. Fix 1kHz noise on a USB microphone, Replace power smoothing capacitor for a larger one: step 1, image 1 of 2 Fix 1kHz noise on a USB microphone, Replace power smoothing capacitor for a larger one: step 1, image 2 of 2
    • Disassemble the microphone as in the video by a fellow hardware hacker https://www.youtube.com/watch?v=DDfCjkH2...
    • The key is; heat the glue - the glue is very tough and rubbery and strong - unlike regular melt stick glue. Be careful to not heat too much the mount in the middle that holds the microphone capsule. Pry-off the top, heat the glue, squeeze in the side grille into a spiral so it can be pulled out the top.
    • Remove screws of the separation plate and pull the board out. Its held in again with the same glue in the rails.
    • Note the capacitor is much smaller than the pads were designed for. For reasons I assume is - cost saving - the factory decided not to use three size of capacitor but just two.
    • Remove the capacitor and replace it with just a bigger one, perhaps from a donor board. Don't worry about the value - it just needs to smooth out the power supply rail for the FET. Ripples in the current are introduced as the devices sends USB packets every 1ms (at 1 kHz). This capacitor smooths those ripples out noticeably.
    • Do not test the microphone outside of its housing as all you'll hear is your typical 50Hz noise from the electrical system.
    Ask FixBot
martin-kokos
100 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 39
All Time: 382
