Up to 20% off select tools
Fitbit Surge Battery Replacement
Views: 21K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
119
All Time:
21,354
Comments: 20
10 comments on steps, 10 guide comments.
Go to guide comments
Completed: 11
11 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Is your Fitbit Surge battery not charging no matter what you do? Read this guide to learn how to replace the battery, but keep in mind that you will need to cut the wristband in order to complete this repair and the band cannot be reattached.
    1. Fitbit Surge Battery Replacement, Battery: step 1, image 1 of 2 Fitbit Surge Battery Replacement, Battery: step 1, image 2 of 2
      • Unscrew all four black 3 mm Phillips screws on the underside of the watch using a T5 screwdriver.
      Ask FixBot
    2. Fitbit Surge Battery Replacement: step 2, image 1 of 3 Fitbit Surge Battery Replacement: step 2, image 2 of 3 Fitbit Surge Battery Replacement: step 2, image 3 of 3
      • Use an X-Acto knife to cut the band above, on either side, and in between the 2 screws.
      • Note: Part of the band is hard plastic.
      • Caution: The band cannot be reattached once it is cut.
      Ask FixBot
    3. Fitbit Surge Battery Replacement: step 3, image 1 of 2 Fitbit Surge Battery Replacement: step 3, image 2 of 2
      • Scrape away the glue beneath the hard shell portion of the band to reveal the GPS.
      Ask FixBot
    4. Fitbit Surge Battery Replacement: step 4, image 1 of 2 Fitbit Surge Battery Replacement: step 4, image 2 of 2
      • Use a PH000 screw head to undo the newly revealed silver 4 mm Phillips screws that were hidden beneath the glue.
      Ask FixBot
    5. Fitbit Surge Battery Replacement: step 5, image 1 of 2 Fitbit Surge Battery Replacement: step 5, image 2 of 2
      • Using a metal spudger, push down on the plastic gray square clamps on the underside of the device to dislodge the whole silver backing.
      • Note: the buttons will also come off.
      Ask FixBot
    6. Fitbit Surge Battery Replacement: step 6, image 1 of 1
      • Use a pick or small flathead to remove the 4 metal clamps holding device together.
      • Use a thin tool to pry the the device apart by lodging it between the clock face and back side of the device.
      • Note: a spudger may not be thin enough to fit in the seam of the device. We used the 6 inch metal ruler from the Pro Tech Toolkit.
      • Go slowly and carefully disconnect two cables before fully opening.
      Ask FixBot
    7. Fitbit Surge Battery Replacement: step 7, image 1 of 1
      • Gently remove the battery.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Keep in mind that the band will need to be cut for this repair and it cannot be reattached.
11 other people completed this guide.
Author
with
Angela Pitts
1,190 Reputation
4 Guides authored
USF Tampa, Team 1-3, Leahy Fall 2016 Member of USF Tampa, Team 1-3, Leahy Fall 2016
USFT-LEAHY-F16S1G3
3 Members
48 Guides authored
10 Guide Comments
I'm about to embark on replacing the battery for my fitbit surge. After having it for over 2 years it requires a charge about twice a day which get annoying.
Does removing/replacing the battery require the moderate soldering skill?
L “Rico” Hirano - Reply Share
Looks like it must.
Chaspsmith - Reply Share
The last photo I think shows the tool prying the force feedback motor, the battery is the white plastic covered slim brick on the top right.
csaba.toth.us - Reply Share
You do not need to cut bands off
Tim master - Reply Share
The replacement battery for the Fitbit Surge can be found here:
It also includes all of the tools (except soldering iron) needed for the repair.
michaelf33707 - Reply Share
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 119
All Time: 21,354
