Fitbit Inspire 2 Wrist Straps Replacement
  1. Fitbit Inspire 2 Wrist Straps Replacement, Wrist Straps: step 1, image 1 of 3 Fitbit Inspire 2 Wrist Straps Replacement, Wrist Straps: step 1, image 2 of 3 Fitbit Inspire 2 Wrist Straps Replacement, Wrist Straps: step 1, image 3 of 3
    • Use a spudger or your fingernail to push back the release lever on one of the two straps on the underside of the Fitbit.
    • You may experience some resistance from the release, but don't use excessive force, as it may damage the release levers.
    Ask FixBot
  2. Fitbit Inspire 2 Wrist Straps Replacement: step 2, image 1 of 3 Fitbit Inspire 2 Wrist Straps Replacement: step 2, image 2 of 3 Fitbit Inspire 2 Wrist Straps Replacement: step 2, image 3 of 3
    • As you pull back the release lever, shift the strap diagonally.
    • Remove from the Fitbit strap.
    • Repeat the process for the other strap.
    Ask FixBot
  3. Fitbit Inspire 2 Wrist Straps Replacement: step 3, image 1 of 2 Fitbit Inspire 2 Wrist Straps Replacement: step 3, image 2 of 2
    • Now that the old straps are detached from the Fitbit, take the opportunity to clean the watch and strap connection points.
    • Use a spudger to clean the inside of the strap chamber. Scrape out any residue or grime that may have built up over the past months or years.
    Ask FixBot
  4. Fitbit Inspire 2 Wrist Straps Replacement: step 4, image 1 of 1
    • Slide the replacement straps into the given slot and the lever will click back into place.
    Ask FixBot
  5. Fitbit Inspire 2 Wrist Straps Replacement: step 5, image 1 of 2 Fitbit Inspire 2 Wrist Straps Replacement: step 5, image 2 of 2
    • The straps should be secure and you can wear your watch again!
    Ask FixBot
2 other people completed this guide.
MarcSerpa
142 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 64
All Time: 944
