Up to 20% off select tools
Fitbit Charge 2 Battery Replacement
Views: 34K
View statistics:
Past 24 Hours:
14
Past 7 Days:
73
Past 30 Days:
363
All Time:
33,900
Comments: 7
3 comments on steps, 4 guide comments.
Go to guide comments
Completed: 11
11 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace a worn-out or dead battery in your Fitbit Charge 2.
If your battery is swollen, take appropriate precautions. For your safety, discharge your battery below 25% before disassembling your Fitbit Charge 2. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
You’ll need replacement adhesive to reattach components when reassembling the device.
    1. Fitbit Charge 2 Battery Replacement, Remove the watch band: step 1, image 1 of 1
      • Before starting, take your Fitbit Charge 2 off the charger and power it down.
      • Remove the watch band on both sides.
      Ask FixBot
    2. Fitbit Charge 2 Battery Replacement, Heat the touch screen: step 2, image 1 of 1
      • Heat an iOpener and apply it to the touch screen for two minutes.
      • The screen is not glued down, but the heat helps to loosen the touch screen assembly from your watch.
      Ask FixBot
    3. Fitbit Charge 2 Battery Replacement, Slide along the left edge: step 3, image 1 of 3 Fitbit Charge 2 Battery Replacement, Slide along the left edge: step 3, image 2 of 3 Fitbit Charge 2 Battery Replacement, Slide along the left edge: step 3, image 3 of 3
      Tool used on this step:
      iSesamo Opening Tool
      $10.99
      Buy
      • Insert an iSesamo into the gap between the touch screen and the watch assembly on the top left corner.
      • Slide the iSesamo along the left edge to the bottom left corner.
      Ask FixBot
    4. Fitbit Charge 2 Battery Replacement, Slide along the bottom edge: step 4, image 1 of 2 Fitbit Charge 2 Battery Replacement, Slide along the bottom edge: step 4, image 2 of 2
      • Slide the iSesamo around the bottom left corner.
      • Slide it along the edge to the bottom right corner.
      Ask FixBot
    5. Fitbit Charge 2 Battery Replacement: step 5, image 1 of 3 Fitbit Charge 2 Battery Replacement: step 5, image 2 of 3 Fitbit Charge 2 Battery Replacement: step 5, image 3 of 3
      • Slide the iSesamo around the bottom right corner.
      • Keep sliding it along the right edge to the top right corner.
      Ask FixBot
    6. Fitbit Charge 2 Battery Replacement: step 6, image 1 of 2 Fitbit Charge 2 Battery Replacement: step 6, image 2 of 2
      • Slide the iSesamo around the top right corner.
      • Slide it along the top edge to the top left corner.
      Ask FixBot
    7. Fitbit Charge 2 Battery Replacement: step 7, image 1 of 2 Fitbit Charge 2 Battery Replacement: step 7, image 2 of 2
      • Place the iSesamo under the top left corner.
      • Feel free to reattach the watch band for this and the next step for a better grip.
      • Pry up the touch screen assembly by twisting the iSesamo sideways to create a gap and unhinge the plastic clips which are holding the screen in place.
      Ask FixBot
    8. Fitbit Charge 2 Battery Replacement: step 8, image 1 of 2 Fitbit Charge 2 Battery Replacement: step 8, image 2 of 2
      • Place the iSesamo under the top right corner.
      • Pry up the touch screen assembly by twisting the iSesamo sideways to create a gap.
      Ask FixBot
    9. Fitbit Charge 2 Battery Replacement: step 9, image 1 of 2 Fitbit Charge 2 Battery Replacement: step 9, image 2 of 2
      • Insert a spudger into the gap on the top edge of your Fitbit Charge 2.
      • Use the spudger to pry up the touch screen assembly.
      • Do not remove the touch screen assembly all the way yet—it's still connected to the motherboard.
      Ask FixBot
    10. Fitbit Charge 2 Battery Replacement: step 10, image 1 of 1
      • Carefully fold the touch screen assembly in the direction of the bottom edge.
      Ask FixBot
    1. Fitbit Charge 2 Battery Replacement, Remove the protecting sticker: step 11, image 1 of 2 Fitbit Charge 2 Battery Replacement, Remove the protecting sticker: step 11, image 2 of 2
      Buy
      • Use a pair of blunt nosed tweezers to remove the black sticker which covering the touch screen connector.
      Ask FixBot
    2. Fitbit Charge 2 Battery Replacement, Open the ZIF connector: step 12, image 1 of 2 Fitbit Charge 2 Battery Replacement, Open the ZIF connector: step 12, image 2 of 2
      • Use the pointed end of a spudger to open the ZIF connector by pushing up the black flap.
      Ask FixBot
    3. Fitbit Charge 2 Battery Replacement, Remove the touch screen assembly: step 13, image 1 of 3 Fitbit Charge 2 Battery Replacement, Remove the touch screen assembly: step 13, image 2 of 3 Fitbit Charge 2 Battery Replacement, Remove the touch screen assembly: step 13, image 3 of 3
      • Pull the touch screen flex cable straight out its socket.
      • Remove the touch screen assembly.
      Ask FixBot
    1. Fitbit Charge 2 Battery Replacement, Unfasten the screws: step 14, image 1 of 1
      • Remove the two Phillips screws securing the motherboard cover:
      • One 2.5 mm screw
      • One 2.8 mm screw
      Ask FixBot
    2. Fitbit Charge 2 Battery Replacement, Remove the motherboard shield: step 15, image 1 of 2 Fitbit Charge 2 Battery Replacement, Remove the motherboard shield: step 15, image 2 of 2
      Buy
      • Use a pair of blunt nose tweezers to remove the motherboard shield.
      Ask FixBot
    3. Fitbit Charge 2 Battery Replacement, Disconnect the heart rate monitor sensor: step 16, image 1 of 2 Fitbit Charge 2 Battery Replacement, Disconnect the heart rate monitor sensor: step 16, image 2 of 2
      • Use the pointed end of a spudger to pry up and disconnect the heart rate monitor sensor flex cable.
      Ask FixBot
    4. Fitbit Charge 2 Battery Replacement, Remove the motherboard: step 17, image 1 of 3 Fitbit Charge 2 Battery Replacement, Remove the motherboard: step 17, image 2 of 3 Fitbit Charge 2 Battery Replacement, Remove the motherboard: step 17, image 3 of 3
      • Use an opening pick to pry up and remove the motherboard which is holding the battery.
      Ask FixBot
    5. Fitbit Charge 2 Battery Replacement, Separate the battery from the motherboard: step 18, image 1 of 3 Fitbit Charge 2 Battery Replacement, Separate the battery from the motherboard: step 18, image 2 of 3 Fitbit Charge 2 Battery Replacement, Separate the battery from the motherboard: step 18, image 3 of 3
      • The battery is mildly glued to the motherboard.
      • Slide an opening pick underneath the battery to cut the adhesive.
      • Don't try to remove the battery all the way yet! It's still connected to the motherboard.
      Ask FixBot
    6. Fitbit Charge 2 Battery Replacement: step 19, image 1 of 1
      • The next steps require desoldering the two battery cables from the motherboard.
      • Use this picture as reference for resoldering during re-assembly or make your own photo if the cable order differs in your model.
      Ask FixBot
    7. Fitbit Charge 2 Battery Replacement: step 20, image 1 of 3 Fitbit Charge 2 Battery Replacement: step 20, image 2 of 3 Fitbit Charge 2 Battery Replacement: step 20, image 3 of 3
      • Use a soldering iron to desolder the first battery cable from the motherboard.
      Ask FixBot
    8. Fitbit Charge 2 Battery Replacement: step 21, image 1 of 2 Fitbit Charge 2 Battery Replacement: step 21, image 2 of 2
      • Use a soldering iron to desolder the second battery cable from the motherboard.
      Ask FixBot
    9. Fitbit Charge 2 Battery Replacement: step 22, image 1 of 1
      • Remove the battery.
      • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard. Replace it with a new battery.
      • Make sure the battery cables are long enough to solder them onto the motherboard before installing new adhesive to the battery.
      Ask FixBot
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
11 other people completed this guide.
Author
with
Adriana Zwink
69,920 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
4 Guide Comments
Donde se compran los repuestos?
Leonardo - Reply Share
Muy buenas las instrucciones! Donde puedo comprar los repuestos y herramientas? Gracias!!!
Nice, thank you!
Mike Beard - Reply Share
Thank you very much.
Erdinç Altınçekiç (TA3LAE) - Reply Share
Past 24 Hours: 14
Past 7 Days: 73
Past 30 Days: 363
All Time: 33,900
