Tools
Introduction
Go to step 1 ↓Would like to replace your damaged or worn out metal ring around your device? This guide will show you how to remove and replace the metal ring that holds the LCD screen in place.
Locate the pin behind the second wristband located on the edge of metal ring.
Insert the pointed end of the metal spudger into the pin hold and push it into opposite direction.
Remove wristband.
3 other people completed this guide.
