Up to 20% off select tools
Fitbit Aria 2 Disassembly
Views: 2.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
23
Past 30 Days:
132
All Time:
2,160
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Tools
    1. Fitbit Aria 2 Disassembly, Preparation: step 1, image 1 of 1
      • Place the scale upside down on a surface that will protect the glass top of the scale and won’t scratch.
      • Remove the battery cover and batteries (if installed).
      Ask FixBot
    2. Fitbit Aria 2 Disassembly, Remove Screws: step 2, image 1 of 2 Fitbit Aria 2 Disassembly, Remove Screws: step 2, image 2 of 2
      • Remove the label in the battery compartment. You can use a small flat headed screwdriver or similar implement to pry the sticker up. (Try to avoid damaging the sticker too much if possible).
      • Use a Torx T10 screwdriver to remove the two Torx screws and set aside.
      Ask FixBot
    3. Fitbit Aria 2 Disassembly, Unclip Base: step 3, image 1 of 1
      • Using a small flathead screwdriver, starting new the corners, pry away the plastic panel from the glass top.
      • Once the gap is wider use larger pry tools to allow you to pull the bottom section away. You may need to use some force to release the clips.
      • Note there are no cables of components connected to the bottom plate so do not be concerned about ripping delicate cables.
      Ask FixBot
      • Once open necessary repairs can be made.
      • If your issue is regarding inaccurate measurement you can remove the feet by pulling them, then remove the feet mounts using a small flat headed screwdriver to release the three clips.
      • Reassemble the feet and feet mounts outside of the unit then reseat them in the clips.
      Ask FixBot
Author
with
Peter Crowther
136 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 132
All Time: 2,160
