Fitbit Alta Wristband Replacement
Views: 13K
View statistics:
Past 24 Hours:
4
Past 7 Days:
36
Past 30 Days:
163
All Time:
13,165
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 13
13 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This is a quick and easy guide to replace the wristband of a Fitbit Alta. No tools are required in the process.
    1. Fitbit Alta Wristband Replacement, Wristband: step 1, image 1 of 1
      • To release a latch, press down on the flat metal button holding the band to the Fitbit Alta. Pull up on the latch to release the band from the body.
      Ask FixBot
    2. Fitbit Alta Wristband Replacement: step 2, image 1 of 1
      • Slide the band up to release it from the Fitbit Alta tracker. Then, repeat on the other side to remove the band.
      Ask FixBot
    3. Fitbit Alta Wristband Replacement: step 3, image 1 of 3 Fitbit Alta Wristband Replacement: step 3, image 2 of 3 Fitbit Alta Wristband Replacement: step 3, image 3 of 3
      • Turn over the Fitbit Alta so the bands are facing upward.
      • Press the latches inward and remove each band by lifting upward.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. When you hear a click , the wristband is secure.
13 other people completed this guide.
2 Guide Comments
Excellent! Thanks so much!
JUDITH DIGENOVA - Reply Share
My band broke off and the tab used for removal broke and I cannot get my remnant of my band off. What are the steps for removing the band if the tab is broken?
godz.gal.52 - Reply Share
Past 24 Hours: 4
Past 7 Days: 36
Past 30 Days: 163
All Time: 13,165
