Fisher Paykel Neopuff Valve System Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
    1. Fisher Paykel Neopuff Valve System Replacement, Valve System: step 1, image 1 of 1
      • Remove the back cover, fixed by four screws.
      Ask FixBot
      • Disconnect the tube from the manometer.
      Ask FixBot
      • Remove the manometer by unscrewing the two retaining nuts.
      Ask FixBot
      • Fit the existing manometer into the new valve assembly panel.
      Ask FixBot
      • Tighten the retaining nuts.
      Ask FixBot
      • Reconnect the manometer tube.
      Ask FixBot
      • Refit the front panel to the back cover with the four screws from step 1.
      Ask FixBot
    2. Fisher Paykel Neopuff Valve System Replacement: step 8, image 1 of 1
      • Carry out the valve system performance test described above. It is recommended to record the lot number of the new valve assembly onto the Set-up and Maintenance Checklist.
      Ask FixBot
Constantine Yap
364 Reputation
2 Guides authored
Cal Poly, Team S1-G6, Zimmerman Spring 2020 Member of Cal Poly, Team S1-G6, Zimmerman Spring 2020
CPSU-ZIMMERMAN-S20S1G6
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 23
All Time: 477
