Fisher & Paykel Heater Plate Repair
  1. Fisher & Paykel Heater Plate Repair, Fisher & Paykel Heater Plate Repair: step 1, image 1 of 1
    • Using a multimeter, you should be able to find continuity when touching any 2 points of the grey heater tracker. If you can't, the element won't heat. If you look closely you will find an interruption in line.
    Ask FixBot
  2. Fisher & Paykel Heater Plate Repair: step 2, image 1 of 1
    • I tried lots of ways to solder a little wire to fix the tiny gap in the grey line but they didn't work. The solder wouldn't stick to the enamel. Those white blobs are the remains of a failed attempt to attach the bridging wire using epoxy putty. Ignore them.
    • What did finally work is the copper painted areas.
    Ask FixBot
  3. Fisher & Paykel Heater Plate Repair: step 3, image 1 of 1
    • The copper paint comes from a rear window defogger kit. This is the one I used. I put 4 layers on (drying a bit between coats). Test for continuity. The paint needs to dry fully before it reads properly. I waited overnight before I retried the dishdrawer.
    • The repair has worked for years since. Although lately I did have to repair another spot. THat's when I nabbed these photos.
    Ask FixBot
Finish Line
Tanya
97 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 24
All Time: 59
