First Act MA2039 Speaker Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
50
All Time:
820
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 25 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
This guide will show you how to remove and replace a blown speaker. Doing this will require a phillips head screwdriver and wire cutters. A soldering tool will also be needed to reattach wires to the new speaker.
Tools
    1. First Act MA2039 Speaker Replacement, Speaker: step 1, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the two 25mm screws that secure back panel to amplifier.
      Ask FixBot
    2. First Act MA2039 Speaker Replacement: step 2, image 1 of 2 First Act MA2039 Speaker Replacement: step 2, image 2 of 2
      • Once screws are removed, lift the panel from the amplifier and feed the battery terminals through holes in battery cartridges.
      • Take the panel off and set it to the side.
      Ask FixBot
    3. First Act MA2039 Speaker Replacement: step 3, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the four 25mm screws that fasten the speaker to the inside of the amplifier.
      Ask FixBot
    4. First Act MA2039 Speaker Replacement: step 4, image 1 of 1
      • Desolder the black and white speaker wires from the contact board.
      • The speaker can now be completely removed from the amplifer.
      Ask FixBot
To reassemble your device, use soldering link provided to solder existing wires onto new speaker, then follow these instructions in reverse order.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 50
All Time: 820
