Up to 20% off select tools
Finding Model Name
View statistics:
Past 24 Hours:
6
Past 7 Days:
21
Past 30 Days:
125
All Time:
916
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Finding Model Name
Introduction
Go to step 1 ↓
This guide covers a few different methods of finding your computer's model number if you can't find it easily.
    1. Finding Model Name, Finding Model Name: step 1, image 1 of 2 Finding Model Name, Finding Model Name: step 1, image 2 of 2
      • Check the exterior of the laptop for a sticker with the model name on it. This sticker may be underneath the battery, or on the underside of the battery, so you have to remove the battery to see it.
      Ask FixBot
      • Use the (Win+R) key combination to open the Run... dialog. Type "control panel" (with no quotation marks) into this box to open the control panel. Click "System and Security", then click "System". Look for a model name here.
      Ask FixBot
      • DirectX diagnostic tool: Press (Win+R). The "Run" dialog will appear. Type “dxdiag” (with no quotes) into this box and click OK. The “DirectX Diagnostic Tool” window will appear. Click on the “System” page and look for a “System Model” entry.
      Ask FixBot
      • Command prompt: Press (Win-R). The "Run" window should appear. Type “cmd” (with no quotes) into this box and click OK. Command Prompt should appear. Type the following into the Command Prompt window, but with no quotation marks: “wmic csproduct get name”. Press the enter key and your model name should appear.
      Ask FixBot
      • Sometimes the model name is printed or labelled on the computer’s motherboard. It is beyond the scope of this guide to explain how to access the motherboard, but this guide may be helpful.
      Ask FixBot
Finish Line
Author
with
Tim Cedar
934 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 21
Past 30 Days: 125
All Time: 916
