Up to 20% off select tools
Fender Starcaster Tuning Heads Replacement
Views: 3.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
23
Past 30 Days:
111
All Time:
3,771
Comments: 4
1 comment on steps, 3 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
If the tuners have broken, become excessively lose, or seized, they will require replacement.
    1. Fender Starcaster Tuning Heads Replacement, Loosen the Strings: step 1, image 1 of 3 Fender Starcaster Tuning Heads Replacement, Loosen the Strings: step 1, image 2 of 3 Fender Starcaster Tuning Heads Replacement, Loosen the Strings: step 1, image 3 of 3
      • Start by loosening the strings. This is done by turning the tuning knob until the string has lost tension.
      • Repeat this for all six strings on the guitar.
      Ask FixBot
    2. Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Tuning Pegs: step 2, image 1 of 2 Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Tuning Pegs: step 2, image 2 of 2
      • Be mindful of the string ends. They may be sharp and could puncture your skin.
      • It may be necessary to use pliers to remove string ends from the tuning peg.
      Ask FixBot
    3. Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Bridge: step 3, image 1 of 3 Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Bridge: step 3, image 2 of 3 Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Bridge: step 3, image 3 of 3
      • After removing the strings from the tuning pegs, slide the strings through the bridge and out of the back of the guitar.
      • If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier.
      Ask FixBot
    1. Fender Starcaster Tuning Heads Replacement, Tuning Heads: step 4, image 1 of 2 Fender Starcaster Tuning Heads Replacement, Tuning Heads: step 4, image 2 of 2
      • Using a wrench, remove the nuts around each tuning head post.
      Ask FixBot
    2. Fender Starcaster Tuning Heads Replacement: step 5, image 1 of 3 Fender Starcaster Tuning Heads Replacement: step 5, image 2 of 3 Fender Starcaster Tuning Heads Replacement: step 5, image 3 of 3
      • Next, remove the threaded retainer sleeve from each post.
      • Don't forget the washer.
      Ask FixBot
    3. Fender Starcaster Tuning Heads Replacement: step 6, image 1 of 2 Fender Starcaster Tuning Heads Replacement: step 6, image 2 of 2
      • Next, remove the screws from the backside of each tuner.
      Ask FixBot
    4. Fender Starcaster Tuning Heads Replacement: step 7, image 1 of 2 Fender Starcaster Tuning Heads Replacement: step 7, image 2 of 2
      • Finally, remove the tuning machine assembly from the headstock.
      Ask FixBot
2 other people completed this guide.
Author
with
Christopher Hartigan
164 Reputation
5 Guides authored
Pasco Hernando, Team 5-3, Prince Fall 2014 Member of Pasco Hernando, Team 5-3, Prince Fall 2014
PHSC-PRINCE-F14S5G3
9 Members
60 Guides authored
3 Guide Comments
Does the 2013 Starcaster take a 10mm tuning peg?
Brian Seese - Reply Share
This is only the removal. Nothing After step 7. What about the actual replacement? What did you replace them with? Did it involve any machining?
Richard Caruso - Reply Share
This is only the removal. What about the actual replacement? What did you replace them with? Did it involve any machining?
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 111
All Time: 3,771
