Up to 20% off select tools
Fender Starcaster String Removement
Views: 2.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
6
Past 30 Days:
22
All Time:
2,753
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Parts
  • New strings
    String gauge is based upon personal preference.
Tools
Introduction
Go to step 1 ↓
There are many different styles of tuners and bridges, therefore, many different methods of removing the strings. This Starcaster has a string-through bridge and standard in-line tuners, so the string changing process is fairly simple.
    1. Fender Starcaster String Removement, Loosen the Strings: step 1, image 1 of 3 Fender Starcaster String Removement, Loosen the Strings: step 1, image 2 of 3 Fender Starcaster String Removement, Loosen the Strings: step 1, image 3 of 3
      • Start by loosening the strings. This is done by turning the tuning knob until the string has lost tension.
      • Repeat this for all six strings on the guitar.
      Ask FixBot
    2. Fender Starcaster String Removement, Remove the Strings from the Tuning Pegs: step 2, image 1 of 2 Fender Starcaster String Removement, Remove the Strings from the Tuning Pegs: step 2, image 2 of 2
      • Be mindful of the string ends. They may be sharp and could puncture your skin.
      • It may be necessary to use pliers to remove string ends from the tuning peg.
      Ask FixBot
    3. Fender Starcaster String Removement, Remove the Strings from the Bridge: step 3, image 1 of 3 Fender Starcaster String Removement, Remove the Strings from the Bridge: step 3, image 2 of 3 Fender Starcaster String Removement, Remove the Strings from the Bridge: step 3, image 3 of 3
      • After removing the strings from the tuning pegs, slide the strings through the bridge and out of the back of the guitar.
      • If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier.
      Ask FixBot
Finish Line
Author
with
Christopher Hartigan
164 Reputation
5 Guides authored
Pasco Hernando, Team 5-3, Prince Fall 2014 Member of Pasco Hernando, Team 5-3, Prince Fall 2014
PHSC-PRINCE-F14S5G3
9 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 22
All Time: 2,753
