Fender Jazz Bass Strings Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
101
All Time:
1,407
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
String replacement of a Fender Jazz Bass is a common replacement on the bass that can be dependent on how often you play and the type of stress you are putting on your strings. Learning the basics of string replacement will allow you to tune your bass more to your personalized liking and to fear not if a string is to break.
String replacement can be a very basic task, however, it is always an option to elevate your string replacement task with tools that might make it easier. These instructions give you a idea of the essential tasks that are required to have fresh sounding strings in no time.
    1. Fender Jazz Bass Strings Replacement, Strings: step 1, image 1 of 1
      • Loosen the strings by turning the tuning pegs.
      Ask FixBot
    2. Fender Jazz Bass Strings Replacement: step 2, image 1 of 1
      • Once the strings are loose, remove them from the tuning pegs.
      • If you prefer, you can also cut the strings off.
      Ask FixBot
    3. Fender Jazz Bass Strings Replacement: step 3, image 1 of 2 Fender Jazz Bass Strings Replacement: step 3, image 2 of 2
      • Reach under the bridge to pull out the end of each string.
      Ask FixBot
    4. Fender Jazz Bass Strings Replacement: step 4, image 1 of 2 Fender Jazz Bass Strings Replacement: step 4, image 2 of 2
      • Insert the end of the string with no knob on the bottom through the bridge first.
      • Pull each string through to the top of the neck.
      Ask FixBot
    5. Fender Jazz Bass Strings Replacement: step 5, image 1 of 1
      • Insert the strings into the indentations on the nut.
      • Wrap the strings around the tuning pegs about two times.
      Ask FixBot
    6. Fender Jazz Bass Strings Replacement: step 6, image 1 of 2 Fender Jazz Bass Strings Replacement: step 6, image 2 of 2
      • Tighten the tuning pegs until the bass is in tune.
      • The standard tuning for a bass is E A D G.
      • You will have excess string hanging off the pegs of the bass.
      Ask FixBot
Finish Line
Matthew Caldera
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 101
All Time: 1,407
