Fender Frontman 15r Power Input Jack Replacement
Views: 8.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
93
All Time:
8,435
Comments: 0
Go to guide comments
Completed: 0
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If your device does not have power, replace the power input jack.
Tools
    1. Fender Frontman 15r Power Input Jack Replacement, Back panel: step 1, image 1 of 1
      • Be sure to unplug the device before proceeding.
      • Use a Phillips #0 screwdriver to remove the four 21.7mm screws holding the back panel to the frame.
      Ask FixBot
    2. Fender Frontman 15r Power Input Jack Replacement: step 2, image 1 of 1
      • Once the screws are out, use a plastic opening tool or spudger to pry the top of the back panel open. There may be some resistance, but it will eventually pry loose.
      Ask FixBot
    3. Fender Frontman 15r Power Input Jack Replacement: step 3, image 1 of 1
      • Once the top is separated, use your hand to remove the back panel from the unit.
      Ask FixBot
    1. Fender Frontman 15r Power Input Jack Replacement, Mounting Bracket: step 4, image 1 of 2 Fender Frontman 15r Power Input Jack Replacement, Mounting Bracket: step 4, image 2 of 2
      • There will be two black wires connecting the top mounting bracket to the reverb box at the bottom of the unit. Label the wires to prevent crossing upon re-installation, then unplug the wires from the reverb box.
      Ask FixBot
    2. Fender Frontman 15r Power Input Jack Replacement: step 5, image 1 of 1
      • Label and unplug the two red wires connecting the mounting bracket to the speaker by pulling them off the nodes.
      Ask FixBot
    3. Fender Frontman 15r Power Input Jack Replacement: step 6, image 1 of 3 Fender Frontman 15r Power Input Jack Replacement: step 6, image 2 of 3 Fender Frontman 15r Power Input Jack Replacement: step 6, image 3 of 3
      • Use a Phillips #1 screwdriver to unscrew the four 36.4 mm screws holding the mounting bracket to the top of the amp.
      Ask FixBot
    4. Fender Frontman 15r Power Input Jack Replacement: step 7, image 1 of 3 Fender Frontman 15r Power Input Jack Replacement: step 7, image 2 of 3 Fender Frontman 15r Power Input Jack Replacement: step 7, image 3 of 3
      • Pull the mounting bracket free from the frame. It may be wedged in very snug, in which case, use a plastic opening tool/spudger to pry it loose from the front.
      Ask FixBot
    1. Fender Frontman 15r Power Input Jack Replacement, Power Input Jack: step 8, image 1 of 2 Fender Frontman 15r Power Input Jack Replacement, Power Input Jack: step 8, image 2 of 2
      • Before disconnecting the wires, label, make note of, or memorize each wire according to where it connects to the power input jack.
      • Disconnect the wire connectors from the back of the input jack by pulling them away from the jack.
      Ask FixBot
    2. Fender Frontman 15r Power Input Jack Replacement: step 9, image 1 of 2 Fender Frontman 15r Power Input Jack Replacement: step 9, image 2 of 2
      • Use Philips #1 Screwdriver to unscrew the two 12.1 mm screws on the exterior of the power input jack.
      • Hold the nut in place while unscrewing the 12.1 mm screws using a pair of needle nose pliers to prevent it from spinning.
      Ask FixBot
    3. Fender Frontman 15r Power Input Jack Replacement: step 10, image 1 of 1
      • Pull the power input jack out of the mounting bracket.
      Ask FixBot
Once the old power jack is removed, to install the replacement power jack, follow the guide in reverse.
Will
46 Reputation
1 Guide authored
Cal Poly, Team 24-30, Regan Fall 2012 Member of Cal Poly, Team 24-30, Regan Fall 2012
CPSU-REGAN-F12S24G30
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 93
All Time: 8,435
