Fender Frontman 15r Mounting Bracket Replacement
    1. Fender Frontman 15r Mounting Bracket Replacement, Back panel: step 1, image 1 of 1
      • Be sure to unplug the device before proceeding.
      • Use a Phillips #0 screwdriver to remove the four 21.7mm screws holding the back panel to the frame.
      Ask FixBot
    2. Fender Frontman 15r Mounting Bracket Replacement: step 2, image 1 of 1
      • Once the screws are out, use a plastic opening tool or spudger to pry the top of the back panel open. There may be some resistance, but it will eventually pry loose.
      Ask FixBot
    3. Fender Frontman 15r Mounting Bracket Replacement: step 3, image 1 of 1
      • Once the top is separated, use your hand to remove the back panel from the unit.
      Ask FixBot
    1. Fender Frontman 15r Mounting Bracket Replacement, Mounting Bracket: step 4, image 1 of 2 Fender Frontman 15r Mounting Bracket Replacement, Mounting Bracket: step 4, image 2 of 2
      • There will be two black wires connecting the top mounting bracket to the reverb box at the bottom of the unit. Label the wires to prevent crossing upon re-installation, then unplug the wires from the reverb box.
      Ask FixBot
    2. Fender Frontman 15r Mounting Bracket Replacement: step 5, image 1 of 1
      • Label and unplug the two red wires connecting the mounting bracket to the speaker by pulling them off the nodes.
      Ask FixBot
    3. Fender Frontman 15r Mounting Bracket Replacement: step 6, image 1 of 3 Fender Frontman 15r Mounting Bracket Replacement: step 6, image 2 of 3 Fender Frontman 15r Mounting Bracket Replacement: step 6, image 3 of 3
      • Use a Phillips #1 screwdriver to unscrew the four 36.4 mm screws holding the mounting bracket to the top of the amp.
      Ask FixBot
    4. Fender Frontman 15r Mounting Bracket Replacement: step 7, image 1 of 3 Fender Frontman 15r Mounting Bracket Replacement: step 7, image 2 of 3 Fender Frontman 15r Mounting Bracket Replacement: step 7, image 3 of 3
      • Pull the mounting bracket free from the frame. It may be wedged in very snug, in which case, use a plastic opening tool/spudger to pry it loose from the front.
      Ask FixBot
Once the old bracket is removed, install the new one by following the instructions in reverse.
Greg Sawers
109 Reputation
3 Guides authored
Cal Poly, Team 24-30, Regan Fall 2012 Member of Cal Poly, Team 24-30, Regan Fall 2012
CPSU-REGAN-F12S24G30
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 17
All Time: 5,377
