Up to 20% off select tools
Fender Frontman 15r Fuse Replacement
Views: 15K
View statistics:
Past 24 Hours:
2
Past 7 Days:
31
Past 30 Days:
137
All Time:
15,275
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If the fuse is blown, the amp will not turn on and a new fuse need to be installed.
    1. Fender Frontman 15r Fuse Replacement, Fuse: step 1, image 1 of 3 Fender Frontman 15r Fuse Replacement, Fuse: step 1, image 2 of 3 Fender Frontman 15r Fuse Replacement, Fuse: step 1, image 3 of 3
      • Be sure to unplug the device before proceeding.
      • Insert any tool with a small, flat end (such as a spudger, flathead screwdriver or plastic opening tool) into the groove in the bottom of the power input and wedge the plastic slot out from the amp.
      • There will be two compartments (one enclosed, one exposed) each containing a fuse. The exposed fuse is the active fuse and the enclosed one is a spare.
      Ask FixBot
    2. Fender Frontman 15r Fuse Replacement: step 2, image 1 of 2 Fender Frontman 15r Fuse Replacement: step 2, image 2 of 2
      • Remove the blown exposed fuse and replace it with the enclosed fuse. If there is not an extra enclosed fuse, a new fuse must be ordered and inserted into the exposed slot.
      Ask FixBot
Author
with
Stephen Figueira
157 Reputation
3 Guides authored
Cal Poly, Team 24-30, Regan Fall 2012 Member of Cal Poly, Team 24-30, Regan Fall 2012
CPSU-REGAN-F12S24G30
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 31
Past 30 Days: 137
All Time: 15,275
