Fender 65 Twin Reverb Preamp Tube Replacement
  1. Fender 65 Twin Reverb Preamp Tube Replacement, Preamp Tube: step 1, image 1 of 3 Fender 65 Twin Reverb Preamp Tube Replacement, Preamp Tube: step 1, image 2 of 3 Fender 65 Twin Reverb Preamp Tube Replacement, Preamp Tube: step 1, image 3 of 3
    • Make sure to unplug the power cord!
    • Take off the back panel by unscrewing the four Phillips head screws on the back of the amplifier. You will find the six preamp tubes are the smaller ones on the right. (The picture only shows five of the six.)
    • Keep the screws in a safe place and mark what part they are for.
    Ask FixBot
  2. Fender 65 Twin Reverb Preamp Tube Replacement: step 2, image 1 of 2 Fender 65 Twin Reverb Preamp Tube Replacement: step 2, image 2 of 2
    • Remove the metal casing by gently pressing up against the case and twisting to the right.
    Ask FixBot
  3. Fender 65 Twin Reverb Preamp Tube Replacement: step 3, image 1 of 2 Fender 65 Twin Reverb Preamp Tube Replacement: step 3, image 2 of 2
    • Using the cloth, remove one tube by firmly grasping and gently pulling downwards.
    • Pulling directly downwards prevents damage to the hookup prongs at the bottom of the tube.
    Ask FixBot
  4. Fender 65 Twin Reverb Preamp Tube Replacement: step 4, image 1 of 1
    • Check the tube for any cracks in the glass. Also check to make sure the filaments are not burnt out.
    • If the tube is still functioning or to insert the replacement or, proceed to step five.
    Ask FixBot
  5. Fender 65 Twin Reverb Preamp Tube Replacement: step 5, image 1 of 2 Fender 65 Twin Reverb Preamp Tube Replacement: step 5, image 2 of 2
    • Take the new replacement tube and insert it into the appropriate slot, making sure that the prongs at the end line up with the correct holes.
    • You should hear a click when the tube is secured in place.
    • Repeat these steps with the other three tubes if necessary.
    Ask FixBot
2 other people completed this guide.
Andrew Exton
141 Reputation
1 Guide authored
Cal Poly, Team 9-27, Maness Winter 2014 Member of Cal Poly, Team 9-27, Maness Winter 2014
CPSU-MANESS-W14S9G27
5 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 69
All Time: 7,149
