Felt Z85 Brake Pad Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
100
All Time:
1,438
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Introduction
Go to step 1 ↓
The brakes on anything that moves are practically the most important part. One of the most frightening feelings is pulling a brake lever and not getting a response. With this guide I hope to never make this a reality for anyone.
This guide contains information on how to replace the brake pads on a 2013 Felt Z85 Road Bike. This guide only requires one tool (4mm allen key) and is fairly straightforward.
This guide can also be used as a reference for any modern road bike with Dual-Pivot brakes.
Parts
Tools
    1. Felt Z85 Brake Pad Replacement, Remove Wheel: step 1, image 1 of 3 Felt Z85 Brake Pad Replacement, Remove Wheel: step 1, image 2 of 3 Felt Z85 Brake Pad Replacement, Remove Wheel: step 1, image 3 of 3
      • Pull up on brake-release lever to spread pads for easy access.
      • Release lever on the right side of the wheel.
      • Loosen left nut on wheel until wheel comes free.
      Ask FixBot
    2. Felt Z85 Brake Pad Replacement, Remove Pad(s): step 2, image 1 of 3 Felt Z85 Brake Pad Replacement, Remove Pad(s): step 2, image 2 of 3 Felt Z85 Brake Pad Replacement, Remove Pad(s): step 2, image 3 of 3
      • Locate Brake Caliper.
      • Use 4.0 mm allen key to remove main bolt.
      • Rotate counterclockwise to loosen.
      • Be careful not to lose both the washer and spacer found in-between the bolt and the brake pad mounting hole.
      • Repeat step 2 to remove the pad on the other side.
      Ask FixBot
    3. Felt Z85 Brake Pad Replacement, Collecting parts (reinstall): step 3, image 1 of 2 Felt Z85 Brake Pad Replacement, Collecting parts (reinstall): step 3, image 2 of 2
      • Brake Pad: The item being replaced.
      • Spacer: This item will be reused.
      • Washer: This item will be reused.
      • 4 mm hex bolt.
      • Note order of mounting hardware for reinstall.
      Ask FixBot
Ryan Marschall
123 Reputation
1 Guide authored
USF Tampa, Team 1-21, Donnelly Fall 2014 Member of USF Tampa, Team 1-21, Donnelly Fall 2014
USFT-DONNELLY-F14S1G21
1 Member
12 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 100
All Time: 1,438
